Question about Samsung WF337AA Front Load Washer
I don't think I am getting enough water to appropriately wash.
How do you know if the water level is appropriate? After the water shuts off during the first cycle there isn't anmy water in the tub, the clothes appear to soak up all the water. Is this correct or should the clothes roll through at least some water as the tub rotates?
    President:
  • Samsung Master
  • 2,651 Answers
This is correct, the machine will only fill the clithes to a saturation point and not much more part that at all, as the cycle progresses and more water is needed it will addd accordingly, yo have an extremely efficient machine there!!!1/3 the water and 1/2 the electric of conventional top loading washers
Posted on Jan 21, 2009
MAH3000AWW FILLS WITH WATER ON WASH CYCLE BUT DOES NOT SHUT THE WATER OFF WHEN IT GETS FULL AND THEN LEAKS ON THE FLOOR. IT IS ONLY THE HOT WATER.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Here is a link to the water inlet valve.Here is a link to the water pressure switch.
Dec 31, 2010 | Maytag Washing Machines
My GEWBB2090G9WW clothes washer just installed and washer overflows - water fill does not shut off regardless of Small/Medium/Large load size selected.
HELLO THERE:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Sep 26, 2010 | Washing Machines
Water does not shut off
If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Feb 15, 2010 | Washing Machines
It overflows water because it doesn't spin it out on the spin cycle
Water-inlet valve
Water-level switch
Aug 21, 2009 | Washing Machines
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
The water will not shut off during spin cycle
Water-inlet valve
Water-level switch
May 23, 2009 | Maytag Neptune Washer
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
Flooding and overfilling
Hi
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 24, 2009 | Amana ALW480DA Top Load Washer
Machine doesn t stop filling during rinse cycle and door unlocks and opens flooding room
Check the following -
Water-inlet valve
Water-level switch
Water-inlet valve
Water-level switch
Good Luck!
Mar 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
At the begining of the wash cycle the water pressure is klight and heavy. explain why.
Hi
Please revert for further assistance and Do rate the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Maytag Washing Machines
Samsung WF337AA Front Load Washer Logo
94 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
