Question about Brother IntelliFax-2820 Laser Fax
Change toner and it comes up with Toner Life End
Remove the new toner cartridge and reinstall, however the fax keeps coming up with Toner Life End.
Can this be reset?
  • david554 Jan 21, 2009
    There does not appear to be a "clear" button
    The only instructions is to clean the drum unit wire using the slider key. The toner is genuin Brother and I have shaken the toner. There is no RESET and holding down the START did not work.
    Genius:
  • 2,120 Answers
Im think you leave the cover open and hold down clear
Posted on Jan 21, 2009
  • Leroy Elliott
    Leroy Elliott Jan 21, 2009
    I've heard of this problem before. maybe it's RESET OR START.
    I thought instructions came in the drum box.
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Tip
Toner life end message
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
on Jul 07, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
"toner life end" message even with new cartridge
Open the front cover
Press the OPTIONS button
Press the START button
Press the number 1 key twice
Close the front cover.
You may need to go through the steps above twice to reset the toner.
Jul 11, 2010 | Brother IntelliFax-2820 Laser Fax
"Toner Life End" with new cartridge in place
take out the toner form the drum, on the left side of the toner there is a white tab sat in a half circle type cut out. it should be located at its far right position, carefully push it anti clockwise until it stops, may need a screwdriver to start it moving as its a bit stiff.
put it back in the drum and give it a try
May 12, 2010 | Brother IntelliFax-2920 Fax
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
4. Press 1,0 .
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 I keep getting a end toner life message after replacing cartridge
Make sure the machine is not in direct sunlight as the toner end sensor is photo-optic. If it's an after market toner or refill...good luck with that. Lastly remove the toner tap on top of it and shake it from side to side and reinstall. The toner may be caked up inside,
Jul 13, 2009 | Brother IntelliFax-2820 Laser Fax
Toner life end
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Dec 05, 2008 | Brother IntelliFax-2820 Laser Fax
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
916 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
