Question about Epson Stylus C67 Photo Printer
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
  • 3 Answers
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Posted on Jan 02, 2014
Inky
  • 691 Answers
SOURCE: Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at http://www.TheServiceManualShop.com if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
Posted on Oct 13, 2007
SOURCE: repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Posted on Sep 18, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
jacklee366
  • 541 Answers
SOURCE: Flashing red lights
this means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
Posted on Feb 19, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Alternate flashing red lights on epson stylus photo 900
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink and paper icons are alternately flashing
If you download SSC Srevice utility from the net (FREE) all you need to do is to reset all your counters and that should solve your problem.
Apr 06, 2009 | Epson Stylus C84 InkJet Printer
Flashing red lights
Feb 18, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson stylus photo 950 printer flashing lights
Ink Overflow -
Solution:
Sep 28, 2008 | Epson Stylus Photo 950 InkJet Printer
Epson won't print and all lights flash
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Repairing
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus C67 Photo Printer Logo
186 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
