Question about Scubapro MK25/G250 Hp Regulator
Extreme loud sound on MK/25
I am a Scubapro Technicician. I received 2 1st MK25 stages for regular maintenance. Owner confess never get a maintenance in 6 or 7 years. Everything OK when I finish them. Intermediate pressure OK. When he was in the water extreme noise coming from first stage and a leak. Abort dive. He brought me back both regulators (same problem). Then I realize they did not have O´ring in piston, between bushing (10600135) and piston. This O´ring is piece number 01050360. I do not know why regulators did not have it, or why he did not have same problem before. Have you heard about it?
Did you check your bulletins from scuba pro ? depending on the actual year of mfg ( you can call scuba pro and give them serial number )
there was a retro fit kit made for the mk 25 first stage of you send me your email i will send the bulletin to you
other wise if you wew working from an earlier service guuide then you would notbe aware of the retro fit kits and pistons some of the earlier schematic will not show you that o ring that you were refering to
Posted on Aug 28, 2009
Strange noise from mk17
Scuba pro has repair facilities everywhere they can fix this problem with a annual service kit.
Feb 26, 2013 | Scubapro MK17/S555 Regulator
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
I have been using my A700/mk25 for six month and recently it has been making a whislting noise when I inhale.
the whistle noise is some thing loose (torn o-ring) inside the second stage. this is covered under warranty. scuba pro offers a parts for life program which is no cost to you if 1st & 2nd stage with a computer are bought at one time. just pay service labor. the whistle noise will be repaired are replaced free under 1 year.
Dec 23, 2012 | Scubapro Mk25 & A700 High End Regulator By...
Scubapro mk 17 slow to move spg needle
the spg hose has a oriface in it so that if the hose burst you do not lose all your air underwater at once. have your scuba shop test it for proper operation.
Aug 08, 2012 | Scubapro MK17/S555 Regulator
"yearly Maintenencae" what is
thay clean and change the o-ring the needly seat and new diaphram its some thing that you do every year to certifi for ins. purposes
Apr 23, 2011 | Scubapro MK25/G250 Hp Regulator
I need to strip down my s555 regulator to find
Check here:
May not have exactly your model, but something very very similar. Also, keep in mind, the second stage will free-flow as an "overpressure safety" if the first stage is malfunctioning. Check your intermediate pressure (should be ~150). If you can't do this, try your second stage on another first stage (any brand), and try another second stage on your first.
If it is for sure your second stage, check for proper adjustment of demand lever, bent/damaged demand lever or diaphragm plate, or damaged valve seat.
Jan 18, 2010 | Scubapro Service Diagrams Scuba Regulator...
With inhalation there seemed to be a brief stop in the air stream and some resistance. This happens regardless of how my second stage is tuned. I have had two other divers to try it and they both felt it...
Is this reg new by any chance??
Or perchance it's due a good service?? Sounds like something is sticking inside..
Alternately, I had a similar problem with my mk25 just after I bought it. The dive center I was in were able to fix it overnight for me so I the weekend wouldn't be a washout and the said afterwards that the problem was one of the seals/valves inside that was a bit of a design flaw. They knew about it and had replacements on hand so it could be worth letting your local service center look at it and see what they think..
It's possible this is it too..
Sep 27, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Scubapro MK25/G250 Hp Regulator Logo
765 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
