SOURCE: mirror effect on hp 2420 PCL6 (network)
Try downloading the Postscript driver instead of the PCL6 driver. There have been a lot of issues in the PCL driver. You might also try the universal driver. Both are list and can be downloaded from HP's website under the support icon.
Hope that helps you.
SOURCE: Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
SOURCE: Why the logo on SAP report is reversal printed
The SAP device types for specific HP printers use PCL5 fonts in the printer for printing. So the old printer driver can solve this problem.
