Question about HP Office Equipment & Supplies
Machine does not send faxes says line surge
1536dnf mfp
SOURCE: Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Posted on Feb 23, 2008
SOURCE: HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Posted on Jul 24, 2009
shawn38
  • 200 Answers
SOURCE: can't send fax from Kyocera KM1650. It won't send
Try turning off the ECM mode when sending to that number. The instructions are in the Fax user manual. If you dont have it go to www.gfbm.net and yo can get a link to Kyocera manuals.
Posted on Feb 18, 2010
  • 16 Answers
SOURCE: FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Posted on May 14, 2010
  • 3 Answers
SOURCE: Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Posted on Jul 21, 2010
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Is there a way to hook up my hp lazer jet pro m1212 nf mfp to be able to send a fax utiling my laptop which is by wifi. In other words no land line available.
Without a dial-up line available for your fax machine, the only other way to fax is via the internet if it's supported by your MFP. Google online faxing or fax via internet for solutions you may be able to use in your situation.
HISTORY
Fax or facsimile was invented as a way to take a printed document, scan it into digital form and transmit it to it's destination in a matter of seconds -vs- sending it via an expensive courier taking hours or days. This is before the internet, Adobe and other players made a way to create and send documents via the internet without the need for a fax machine and dedicated phone line. While faxes may still be sent that way when the printed document is the only media available, faxing has died off considerably. Most large companies now have ways implemented to move documents digitally without the need to fax. I predict the fax portion of a MFP to disappear in the not too distant future. Earlier MFP's didn't include a fax feature and one had to but the next model up to get it, now it's included in nearly every MFP. Adobe's PDF format with the ability to fill in the forms fields electronically (as in your US taxes) without having to have expensive office software made printing and faxing a thing of the past. Don't be surprised if the business or other entity requests you, and all of us, to submit a PDF document to their business email address rather than a fax.
Good luck with your quest!
Oct 15, 2013 | HP LaserJet Pro M1212nf MFP -...
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
I work IT Support. I have a user that cant send/receive fax from xerox phaser 3300 mfp. They can scan/print fine. Thoughts?
check the fax line. Plug that line into the regular fax machine to see if you can receive/send from there. What where you should start. Thanks
Apr 12, 2011 | Computers & Internet
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
We have a HP colour laser jet CM2320nf MFP and when we try and send a fax it comes up with error report Comm Error 345. Please explain
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
Nov 27, 2009 | HP Laserjet CM2320nf All-In-One Color...
Have setup hp laserjet M1319 MFP series trying to fax but it does not seem to be sending it keeps redailing, phone line is in and i set it up by means of the cd that came with it
I have a different HP MFP, but had a similar problem. HP helpdesk wasn't able to help (had me update the bios, restart, etc.). I stumbled upon a similar problem on FixYa and found out that some of the MFP's aren't compatible with an office on a multi-line telephone system (something to do with analog).
I contacted my telephone service provider (which happened to be cable) and they made some changes to that line while I was on the phone with them. Worked perfectly ever since. I hope this helps you. Good luck!
Jun 25, 2008 | HP Office Equipment & Supplies
Wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Aug 21, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
843 people viewed this question
Seeker5211
Seeker5211
