Question about Alesis DM6 Electronic Drum Set
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
Compared to the other pads, the volume on the kick pad is very low. i adjusted the module volume but compared to the other pads, the kick is really low and so doesn't provide the right bass sound
  • 3 Answers
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Posted on Jan 11, 2013
  • 1138 Answers
SOURCE: i own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
Posted on May 18, 2010
  • 5603 Answers
SOURCE: Ihave an Alesis D4 drum sampler.I have not used in
Some of the Alesis products have a setup and data memory backed up by a battery. It is POSSIBLE that your battery expired and took the sound memory with it.
Investigate if you have a battery in yours (buried in the guts) and check the voltage. It should be above about 3 volts.
If it is below that, replace the battery and find another unit to clone the data from.
Posted on Sep 24, 2009
  • 5603 Answers
SOURCE: alesis drum control pad has very low output
Most of these use a Piezo disc pickup and often the disc can become dislodged.
Not sure what drum pad model you have.
Posted on Feb 21, 2010
  • 5603 Answers
SOURCE: My Dm5 drumkit module keeps intermittently
Intermittents are hard to find the cause of... but let's give it a shot...
Things to try or verify:
1, Verify power connector is fully seated and supply is correct one and is producing the desired voltage..
2. Verify that the amp this connects to is powered by the same wall receptacle. (this is a ground loop noise issue) Also don't let mic's or other electrical equipment touch the drum pad mounting system.
3. Verify you are not inadvertently generating static discharges. If you find yourself drawing sparks when you touch things this is an indication of static. if this is a problem, raise humidity to 40%.
4. If unit is subject to heat, try cooling with a fan to see if it helps the situation.
5. Verify the unit is NOT being vibrated.
6. IF THE UNIT is quite old, verify an internal backup battery is not depleted... they usually are about 3 volts when OK.
Posted on Jun 26, 2010
  • 5603 Answers
SOURCE: I had just recieved a brand new DM6. Upon setup
First thing to look at is the plug you are using a TRS, that is has three connections for the SNARE drum. If you partially put a TRS cable into the jack, the Tip will touch the Ring contact instead of the Tip contact. Now notice that the SNARE has a TRS plug while the kick has only a TS.plug. Could these be mis-labeled? The SNARE is the TRS and the kick is only a two conductor. If these are correct in your unit, then the jack in the kick drum itself must be broken and further that type of failure is really hard to visualize as it would require the tip contact of the jack to be drastically bent so that the plug has to be partially out to work.
So... first verify that the KICK cable has a two wire plug that is DIFFERENT from the three wire plug used on the SNARE (the snare has two pickups, one each for the head and rimshot) Should they possibly either mis-marked the cable plugs OR put the wrong plug on the Kick cable this would be the problem.
Posted on Jan 12, 2011
Good morning,perhaps I should elaberate a bit further upon my already sytated problem.
Try to find a replacement. If not have a service center with a schematic make a new one.
Dec 05, 2014 | Alesis Music
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM7 bass drum wont work
the solder on my kik keeps breaking off. you might have sensitivity issues. it can be adjusted on module.
Jan 22, 2012 | Alesis DM7 USB Electronic Drum Kit
My bass drum stopped working. The module wont pick up any signal and ive tried everything short of replacing it. Not sure if its the wiring the module or the drum sensor itself.. Everything else works just...
Verify the module by connecting a different pad to the bass drum and see if you can trigger the bass drum sound. This would test the module. Now connect the bass to a different input and see if it will trigger that input. SOME of the triggers have a very small potentiometer in them. I have seen vibration break this pot loose rendering the unit inoperative. Also some people have pushed a screwdriver into the pot too hard and broken it off. Once you know it is the bass trigger, open the unit and look for damage. The sensor is usually a piezo disk. These can break away from their attachment. Reattach with contact cement after cleaning the residue.
Apr 14, 2011 | Alesis DM6 Performance Electronic Drumset...
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
Alesis DM6 Electronic Drum Set Logo
327 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
