Question about Saws
How do you change the blade on a craftsman miter saw model 315212110
Lost manual; want to know how to change the blade on a sears craftsman miter saw model 315212110
SOURCE: Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
Posted on May 02, 2009
efs_perpends
  • 1996 Answers
SOURCE: need to change the blade on a craftsman 10
First off, unplug the saw. No need to remove the guard, though you may have to loosen the cover over the lock nut to access it on some saws.
Look for an arbor lock button on the back side of the blade housing or motor, to lock the blade in place.
Hold that down and use a wrench to loosen the nut holding the blade on.
If you don't have an arbor lock, you'll have to wedge a 1x 4 or 2x4 under the blade and hold pressure on the handle to keep it from spinning while you loosen the lock nut. Once it's loose, spin it off and remove the washer and blade, replace and retighten the nut.
Should be pretty straightforward, as long as you have no power to the machine and lock the blade from turning, not too much can go wrong.
If you want to find an online manual with instructions for your saw, please try Sears online support site at www.managemyhome.com.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 14, 2009
protek480
  • 1723 Answers
SOURCE: need a owners manual for a Sears/Craftsman 10inch
Go here:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0803498.pdf
Posted on Sep 03, 2009
Testimonial: "wow-- thanks a million! exactly what i was looking for. "
  • 1214 Answers
SOURCE: Have craftsman 12 inch combination miter saw and need owners manu
I found a copy by going to the Sears Parts Direct website, then select the link on the right that says "View Manual". It will take you to the Manage My Home website, where you will find a button for "View Manual".
I would upload to Fixya, but I cannot get the Manual upload link to work.
Posted on Dec 14, 2009
agent91
  • 2100 Answers
SOURCE: I have a craftsman table saw model 137.248830 and
You should have 4 bolts holding the trunnion on to the table, just loosen these bolts up a little, tap the trunnion with a hammer, the right way, put a straightedge on the blade fully extended and measure across the table to a dado slot, front and rear, tap it till it is exact, tighten bolts and check again. This should do it. You can check your fence the same way. hope this helps.
Posted on Jul 26, 2010
Craftsman 10 compound miter saw. Model 172.243600. Screeching sound when trigger released.
Hello Kenneth Larsen,
Although I am normally LOATH to recommend going
to SEARS (bad personal experiences (many))...
I would suggest in THIS CASE...
That should be the sound of the BLADE BRAKE...
>> (an important SAFETY FEATURE) <<
If the blade is NOT STOPPING on trigger release...
Go to
Water Filters Lawn Garden Appliance Parts
and enter your model number there for parts,
help & live support...
When you get YOUR PARTS or REPAIR estimate
check out OTHER sites for COMPETITIVE pricing...
I personally THINK it is possible for SEARS to
perform adequately... They just need CLOSE
SUPERVISION.
Carnac the Magnificent
Apr 27, 2018 | Craftsman Saws
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
I just opened a 12"
As this is an unused machine, take it back to Sears for replacement (Sears used to have a 'satisfaction-guaranteed' policy--hope they still do)! It appears that the frame is for a smaller saw blade than 12". Good luck!
Nov 28, 2010 | Craftsman Garden
Where can you find a owners manual for a craftsman miter saw model 315.23730?
you can try "managemyhome.com" and under manuals type iin your model. thati is where most of the sears manual are locaed.
Sep 24, 2010 | Craftsman Saws
Yeah, I sure could use some help. I have an older craftsman table saw. It is a Flex-Drive. Model # 113.241691. I acquired it from someone that didn't have the manual. Needless to say, that leaves me with...
Don, go to "managemyhome.com and type in your model number under the manual section. Have plenty of paper ready it is 52 pages long and will instruct you how to align the saw along with other solutions to your many problems. Let me know if you need more assistance
Sep 10, 2010 | Craftsman Saws
How to change a blade in a sears 10" compound miter saw
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Aug 31, 2010 | Craftsman Saws
I have a craftsman professional model 10" cabinet saw, 3 yrs old. Been working great, just noticed blade is not square to miter guides. Where is adjustment Clfavia@yahoo.com
you can try going to managemyhome.com with your model number for an owners manual for the adjustments that you need. Let me know if you still need assistance.
Aug 08, 2010 | Craftsman 10" Table Saw
Dec 14, 2009 | Craftsman Saws
Have Craftsman 8 1/4'' miter saw and I bought an 8'' blade--saw leaves approx 1/8'' on end of board. can I adjust saw to compensate?
I went to Sears.com and downloaded the owners manual to fix the problem. I had missplaced my manual.
Thank you
Nov 29, 2009 | Saws
Saws Logo
67 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
