My PC just froze up and just won't to get of up
  • 27,725 Answers
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue. Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop. Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery. Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
if it does not start in safe mode it could well be a hardware problem
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
or it might even be a virus until you have your laptop up and runing you wont be able to run your antivirus software. another possible reason could be a memory dump running to many programs at the on time placing to much strain on the CPU central processing unit installing more ram will overcome this or uninstalling unecessary programs the other option. If you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible Hope this helps
Posted on Jan 09, 2013
My nokia lumia 610 has froze while updating and now has a black screen with a image to connect to pc
you need to connect it to the pc to finish the update then it will go back to normal
Jun 21, 2013 | Cell Phones
My Cisnet PC has a new motherboard (only been used 5 months) and has froze up on me twice the last week...it won't turn on again unless I let it sit overnight...this last time, though, nothing com
Could be a possible hardware problem. When you say new motherboard, was there an issue with your old one? Were you given the exact same model?
Also, maybe an issue with your power supply.
Oct 19, 2012 | ZT Group Cisnet PC Desktop
Ford taurus 2001 car start but once the car is cut off it won't start up again until it cools off the car is not running hot.
After you kill it, when you try to start it back up, does the starter turn the motor? Or is it froze up (will not turn over)?
Mar 12, 2012 | 2001 Ford Taurus
WS-65511 won't turn on
Hello
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Pc froze, I unplugged it, now it has power but won't boot
Unplugg from power.
Remove the hard disk and re-fix it again.
Do the same with the CMOS battery.
Connect power and start the PC.
Hope this helps.Thanks!
Oct 20, 2011 | ASUS P4SDX Motherboard
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Gateway GT5082 Media Center Computer - Froze. When I turn it on, I get a blank screen and a single, consistent beeping. Once I was able to F8 to restart, but then it happened again and it won't come...
That is a ram problem. Take em out and reseat them, and then one at a time, if more than one.
until something works. then is nothing works, get new ram.
Aug 06, 2011 | Gateway GT5082 PC Desktop
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
