Question about Canon Office Equipment & Supplies
Sir , no panel display in canon ir 3530
Sir, i have canon ir 3530 , in which no display in main panel , i have replaced the RAM & DC 2 BOARD ALSO , but still no display, can u please tell me what else i can check in the machine.
  • 56 Answers
SOURCE: ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Posted on Jan 27, 2008
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 47 Answers
SOURCE: canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
Posted on Jul 26, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Dec 26, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Hello i have my machine Ir 3530 i want to change the language from dutch to English
Dear
go to COPIER > OPTION > BODY
<Adjustment method>
XXYYZZAAXX: Country (UP), YY: Language (ja), ZZ(00) Destination,
AA(00): Paper size type
The display contents conform to the display method of
(COPIER>DISPLAY>USER>LANGUAGE). Enclosed in the brackets
are defaults. The country and language are only displayed.
<Operating procedure>
1) Select <CONFIG>.
2) Select an item to reverse its display. Then press the + or - key to change
the contents.
3) Each time the + or - key is pressed, the contents change sequentially.
4) Display the intended contents at all items and press the OK key.
5) Turn the main power switch OFF and ON.
thanks.
Jan 29, 2015 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
Dec 15, 2012 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon ir 3300 error code E000805-002
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E003-0000
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
There is power in my canon copier but there is no display appear what is the possible problem.possibly the mother board?
Its hard to say without seeing the problem, but if the panel is complely black and without power, the trouble can be in LCD panel or wireing or dc controller ( main board ).
Call service!
Sep 06, 2011 | Canon iR 2016i Black and White Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
44 people viewed this question
old marine
old marine
