Question about HP OfficeJet 5110 All-In-One InkJet Printer
Error code c00e0402 turn power off and on'
Hello, i have the above make and model printer and when ever i turn it on it says 'error code c00e0402 turn power off and on' i have repeated this proceedure countless times for it keep saying the same thing. i have tried pushing all feature buttons to gain access to menues on the printer but this error message has the printer in a freeze mode. There is one green light and one amber light that repeatedly flashes. Please give me some direction.
many thanks
bradie
  • 1 more comment
  • bradie_clark Jan 21, 2009
    yep well done ****!!!
  • bradie_clark Jan 22, 2009
    you an idiot
  • Anonymous Mar 02, 2009
    I have a HP psc 750 that is doing the exact same thing! HELP?????
What you do is you call like a teknickell guy that works with that kinda prob ya no?
then ya lik hope for da best ya no?
Posted on Jan 21, 2009
  • jonathanbaum Jan 21, 2009
    Jonathan Baum gave like a reall goood answa ya no?
  • jonathanbaum Jan 22, 2009
    yo! girl whats ur prob, man? i was just tryin ta help! yo if u wanna say my solutions inappropriate, then girl i will llike get so dissed so just like take a chill pill, girl
Hp officejet v40 Error c00e0402 Please Help!!! i tried Solution #6 on, #5 on & #569 on simultaneously, but still i get the Error c00e0402
The error code c00e0402
C = Hardware
2nd, 3rd and 4th Digits and 7th and 8th Digits (5th and 6th are always zero)
2nd, 3rd and 4th digits
00e = Hardware (with any 7th and 8th digit)
Make sure that the front panel bezel is securely installed and that all access doors are closed.
Verify that all packing material was removed from the product or that no paper jams exist.
If the HP product has been in the cold, unplug the power cord and allow it about an hour to reach room temperature. Plug the power cord back in.
The issue can also occur if the white reference strip for the scanner assembly is missing or extremely dirty. Clean or replace as necessary.
Oct 29, 2009 | HP OfficeJet V40xi InkJet Printer
Error code 71
That is a laser alignment issue...
You might get lucky:
1. unplug printer power cord from wall or powerstrip.
2. Turn ON printer (without the powercord plugged in).
3. Plug in powercord and turn ON printer again.
If error code 71 remains .... repeat above steps.... but I would advise replacing ($180 ~ $240) instead of repairing ($150)...
Hope this helps!
Sep 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Problems with HP OfficeJet 5110 All-In-On
System error C00exxxx
1. Verify that all packing material is removed from the product and no paper jams exist.
2. Make sure that the front panel insert is securely in place and that all doors or panels of the product are closed.
3. Disconnect the power cord from the HP product, wait 5 seconds, and then reconnect the power cord.
4. If the HP product has been in the cold, unplug the power cord and allow it about an hour to reach room temperature before reconnecting the power cord.
5. The problem can also occur if the white
missing or dirty. For information on cleaning the scanner strip, go to HP document General Cleaning of an HP All-in-One or Fax Product (bpu01831).
If the message reoccurs, contact HP technical support for assistance.
Jan 20, 2009 | HP OfficeJet 5110 All-In-One InkJet...
G 55 Office Jet error code
Are all the lights flashing....probably a main board.
Inkworks
866-381-0541
Oct 20, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Error code on 5300 printer
turn off the printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error
while power on display massage eerror c00e0402 . how to solve problem?
Oct 23, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 5110 All-In-One InkJet Printer Logo
374 people viewed this question
Seeker5211
Seeker5211
