Question about Nikon COOLPIX S9 Digital Camera
Wont work i insert the battery and press on and the camera turns on but it wont work. it wont shut off, i cant change any menus. but i can transfer pics. i have to remove the battery to shut off.
  • cocodelpech May 20, 2008
    its dead, no reason
  • quick13 Jun 15, 2008
    My camera lens won't close, I take out the battery and reinsert it, then the camera will turn on, but freezes up and won't work. Cannot shut the camera off, must remove battery to do so. Very frustrated...only had camera 1 year!
    Genius:
  • 2,985 Answers
Nikon Tech support team may help depending on the age of the camera- there is no economic repair option however.
Posted on Jul 01, 2007
Camera shuts off when shutter button is pressed.
I'd try replacing the battery first. It is common for a low power battery to not allow the camera's computer to read what it is supposed to do correctly. If the new fully charged battery doesn't fix it, I'd then contact customer service.
Apr 29, 2015 | Canon PowerShot S2 IS Digital Camera
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
I just tried to transfer my pictures onto the computer from my camera and when i unplugged it, it didnt wanna turn on anymore.it wont even turn on when its plugged in.its werid i was just working a second...
Sounds like you forgot to use the "safely remove hardware" function when you unplugged the camera. Try this.. remove the card and battery...press every button....leave it alone for 20 minutes....insert the card and then the battery...turn it on.
Nov 08, 2010 | Kodak EasyShare M530 Digital Camera
I uploaded the pics from my c513 and now i cant get the camera to turn on i have new batteries and even if i plug it into my computer it wont even recognize it now
Sounds like you pulled out the camera without using the "safely remove hardware" function. Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jun 14, 2010 | Kodak EasyShare C513 Digital Camera
How do you transfer pictures from your camera to a memory card?
once you have the memory card in, turn on your camera.
press the "play" button, if you have some pics on ur memory card you will see these. press the menu/ok button and scroll down until you get to "copy." click on copy and then choose internal to memory card...then choose individual pics or everything that is in ur internal memory. hope this helps!
Dec 30, 2009 | Fuji Finepix Z20fd Digital Camera
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
Camera wont turn on
try to check the battery contacts of the camera...you might need to 'wipe' a contact cleaner to clean it. Caution: Be careful on working with chemicals with your camera. If still no luck...refer to a qualified service tech
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Important photos are stuck in the internal memory of my camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
May 27, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Digital Camera Wont Transfer Pics to Laptop
You can use external usb card reader for transfer the pictur. the camera port not working for problen in the port. you can repair with by heelp of soldring the port.
Jan 23, 2009 | Kodak Easyshare C813 Digital Camera
FZ5 to PC download problems
My golden rule with any digital camera is to ignore the cr@p software that comes with it - it is NOT required to download the photos off the camera. Simply (assuming you're using Windows XP) goto "My Computer", select the removable drive that is the camera (e.g. drive E:), go down a few levels of folders and you will see the files - select and copy or cut.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Nikon COOLPIX S9 Digital Camera Logo
141 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
