Question about D-Link AirPlus DI-524 Wireless Router
Does my DI-524 have a WPS button and if so, where is it?
De Guyver
  • 123 Answers
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Posted on Feb 16, 2006
De Guyver
  • 123 Answers
De Guyver
  • 123 Answers
SOURCE: enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
remt23c
  • 78 Answers
SOURCE: disabled dhcp, cant access router with browser
the default ipaddress for that is 192.168.0.1 you will need to set your computer with a ip address like 192.168.0.2 then you should be able to access it. be sure to change your computer back to DHCP after you reset the router
Posted on Dec 26, 2007
mewms_14904
  • 1027 Answers
SOURCE: method of connecting Dlink wireless router DI-524 to computer
On the back there should be a reset to reset to default settings.
Posted on Apr 04, 2008
Network adaptor failed on my Dell laptop. Purchased a netgear N150 wireless USB adaptor. It asks me to push the WPS button on my router (probably a software button. How do I get there? and what do i do?
I believe that if you have a NetGear router, some of these have an 'automatic configuration' button, that will talk to NetGear wireless adapters and configure everything for you.
If you don't have a NetGear router you should be able to manually configure the wireless network if you have the details of the wireless key, etc.
Hope that this is of some help to you
Oct 17, 2010 | D-Link AirPlus DI-524 Wireless Router
My DI-524 router flashing power light and flashing 4 light
try doing a factory reset on the router - you will need to know all the settings in the router as these will be needed to be re-entered button or hole on the back labelled reset , hold the button - or using a untwisted paperclip in the hole - for 10secs The router will now be reset
Mar 07, 2010 | D-Link AirPlus DI-524 Wireless Router
I have router DI-524 and am unable to connect to internet thru this router. But it says, it is connected
I would do a hard reset by pushing the small button on the back. You will need a small pen to push it. Push and hold down button till the lights flash I would/ say 10-15 seconds should be good enough. Once it's reset try setting up all of your settings again. Remember if you have dsl you will need you username and password to be inputed in some cases. If it is broadband most likely you will not have to bother with username and pass hope this helps.
Nov 30, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I secure the network
The securing process in your wireless router is set by choosing the "Wireless Settings" (with my Netgear, anyway) screen. The bottom portion of the screen lets you set various things re. security, like WEP, WPS-PSK (TKIP), WPA2-PSK (AES), and on. Different levels of security demand different types of passwords as well.
Nov 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Does DI-524 spport WAP
It looks like the 524 will support WPA-PSK.
Try this:
http://support.dlink.com/faq/view.asp?prod_id=1506&question=DI-524
If your 524 doesn't look like this you amy need to update the firmware.
Good Luck
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Ip address
By default the IP address should be 192.168.0.1.
If it will not accept it
>Make sure your computer is wired or connected to your DI-524
XP version
>Try going start>run > type in CMD
>on the black screen type in ipconfig and hit enter.
>Look for the Default Gateway that would be the IP address that your DI-524 is using.
Windows Vista
>Click Start>All Programs > Accessories > click on command prompt
>type in ipconfig
>Look for IPV4 for the Default Gateway and that would be the IP address of your router.
If not allowing to access the login page, try pressing the reset button for 15 seconds at the back of your DI-524 but pressing the reset button will reset the setting of your wireles setting. Once your press the reset button type in 192.168.0.1 on the address bar and you should be having the login page. use Admin/admin for the username and leave the password blank and click ok...
Jan 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
2,222 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
