Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Panafax dx 800 incomplete info code 400
Incomplete info code 400 on a fax
MitchSchaft
  • 25 Answers
SOURCE: Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Posted on Jan 25, 2008
SOURCE: Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Posted on Aug 07, 2008
leroyal
  • 2120 Answers
SOURCE: dx 800 fax machine
Only one sender, or all sender's?
Unplug the machine and replug. If it has an OUT button, make sure it's lit.
When all else fails...
Unplug machine
Hold down energy saver key
plug in
scroll down to SHIPMENT SET
press set
set
wait for reboot
Posted on Sep 01, 2008
tech435
  • 284 Answers
SOURCE: Panasonic Panafax DX-2000 Super G-3
try to do a lbp fuser reset and lbp error log clear and let me know if that helps
Posted on Oct 15, 2008
FixinFax
  • 3085 Answers
SOURCE: DX-800 panafax says toner is out even when replace.
You need to call a panasonic tech to install a toner sensor spring kit.
Posted on Dec 14, 2009
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
Panafax DX-800... shows memory full 100%. Scanner does not work. Pls advise how to cancel all memory as I do not need the incoming documents. Thanks.
Unplug the machine from the rear
Hold down the ENERGY SAVER key while plugging back in
Scroll down to ALL JOB CLEAR
Press SET
wait for the machine to INITIALIZE
Feb 08, 2010 | Panasonic Panafax DX-800 Plain Paper Laser...
Our dx-800 reads OUT OF TONER INFO CODE = 041. We have replaced the toner several times. This was intermitant over the last month. We would unplug and repower and it would go away for a while.
Toner sensor holder kit (The silver part in center, directly below the toner) needs to be replaced by an authorized Panasonic repair center. Call Panasonic for one in your area.
The part should cost no more than $30-50. takes 5-10 minutes to replace. Most service places charge minimum 1 hour fee and possibly travel fees. so you are looking at $125-250 repair bill.
If the unit is out of warranty, Panasonic won't do it for free.
I have replaced the sensor kits on numerous DX-800 and it basically avoids displaying the toner errors, and you replace when print becomes light...the good old fashioned way.
Panasonic Support: 800-211-7262
Jan 26, 2010 | Panasonic Panafax DX-800 Plain Paper Laser...
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Won't answer and won't dial.
Use a plan phone to test first before attaching it to fax....
Mar 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Dx 800 fax machine
Unplug machine
plug in
press set
set
wait for reboot
Aug 20, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
145 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
