Question about Panasonic Microwave Ovens
Model NN SD698S stopped working with H98 showing
  • 297 Answers
SOURCE: I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Posted on Apr 17, 2009
SOURCE: panasonic genious sensor inverter 1300w nn-t664sfx
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Posted on Apr 08, 2010
  • 8909 Answers
SOURCE: H98 ERROR CODE ON A
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Posted on Mar 10, 2011
Daniel S
  • 4323 Answers
SOURCE: H98 code appear in my
Hi
H98 error code means high voltage diode failure and to solve this issue the inverter board should be replaced. Repairing Microwave is only recommended to be done by a professional just because of the voltage present inside the unit. Hope this helps...please post back for further assistance.
Daniel
jumptrout51
  • 3361 Answers
SOURCE: Door closes but will not
There are micro-switches in the control panel that are out of adjustment or sticking.
The switches have to make contact with the door latches when the door closes.
Adjust the position of your switches.
Posted on Jun 11, 2011
Nn p295 microwave stops after 3sec
You could have a problem with the inverter board or magnetron. If it shows a code like "H98", then it's probably an inverter issue. To test, go to:
Http:://educypedia.karadimov.info/library/Inverter.pdf
Nov 13, 2016 | Microwave Ovens
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
Door closes but will not turn on . Have to slam it Model # NN-SD698S Inverter S/N 6810190386
Jun 11, 2011 | Panasonic Microwave Ovens
Hi, I have a Panasonic Inverter microwave NN-Sn9688. It's less than a year old and when you press the START button H98 appears and it will not start. Everything else works, clock etc and reset/stop...
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes: http://www.applianceaid.com/micro_faultcodes.html#panasonic
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&Ntt=NN-SN9688&x=28&y=20
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Kelly
Sep 10, 2010 | Panasonic Microwave Ovens
The microwave shuts itself off after 3-5 seconds on all cook settings
i have model # nns 977s it shut of and show H98 what is wrong?
Dec 26, 2009 | Panasonic NN-T964SF Microwave Oven
generation system
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
