Question about Bose Wave Radio
Bose radio display doesn't show at all
Hi - This radio has some years on it but is not ancient by any means, can't remember exactly when it was purchased.
I got the display to work for just a little while but then it faded to black once more. Replaced the battery but I don't think that matters.
Radio does not have a CD player.
I saw a tip here to hold down the clock set button while adjusting volume but this did not work. Have unplugged & plugged in several times, radio will play just no display.
Would love to be able to use it for my clock radio, really appreciate any help you can give!
Thanks!
Jan
  • 6 more comments
  • janib Jan 21, 2009
    Thanks for the superfast answer! I'm good with the alcohol and toothbrush and hope I can take the thing apart but not sure exactly what I'm looking for with the lcd connector and lcd IC.
    OK - I probably won't play with this until the weekend.
    Sounds like it will work though!
    Thank you for your patience! :)
  • tezzy138 Jan 25, 2009
    it was on and I was listening to music and than there was a noise and it wnet dead i know the batteries are old and one was corrode but i thouhght it will still run without batteries am i wrong/
  • janib Jan 25, 2009
    XD, unfortunate medical things going on here - everyone isn't young and whole like you. I do appreciate your advice and will give it a try and report back as soon as I am able. I expect it to work fine. Again, thank you for your patience.
  • janib Mar 26, 2009
    Hi again XD, all the buttons on my radio are on a center panel on top, like the pic of the older model above. Looks like it would be possible to pop the top off with a screwdriver in a little slot on the back that might be for that purpose. Tried it real easy and it seems to be mounted on there real good though. Do I take off the top by taking out the 4 screws in the bottom? Hope I'll be able to get it put back together.
  • Anonymous Apr 02, 2009
    Radio fell off curio cabinet,no light display,screenblack
  • sclark162 Apr 28, 2009
    I have the cd wave radio with the buttons on top. It's about 6 years old and a few days ago the display just went black. When I press any button, the display comes back but only for about 5 seconds then blacks out again. All audio functions still work just fine. Am I out of luck? Thanks.
I just posted a similar problem and did 2 more minutes of research on this site to figure it out. Hold down the 'cd mode' and press the on/off button. This turns the display on or off.
Posted on Apr 28, 2009
  • 1,800 Answers
Take it apart and use alcohol and a tooth brush to clean the lcd connector and lcd IC.
Posted on Jan 21, 2009
  • 1 more comment
  • Jalal Sordo
    Jalal Sordo Jan 21, 2009
    LCD = the screen.
    will see anything connected to the screen such as wires and Internal Circuits and nozzels.
  • Jalal Sordo
    at least give me a rating jan.
    XD
  • Jalal Sordo
    Jalal Sordo Jan 25, 2009
    yea just try new and fresh ones.
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
I can't get any power to the unit
Tay to contact the nearest bose authorised servicing center because the spares of Bose wave radio is difficult to get out side. Also it uses a mutilayer circuit boar with SMD components. Only A well trained service tech will be able to rectify the fault.
Ajin
Feb 27, 2012 | Bose & Wave& Music System
The time display is dark. the radio works and I can set an alarm but the time display is dark. I seem to remember there is a battery somewhere that may need to be replaced.
it may be that the display died or it not getting enough light on the screen because it has a senor that when the lights turns on it will be brighter or if this does not work call bose at 973 644 BOSE
Jul 10, 2011 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Bose Lifestyle 12 "no display" fix
There is a service available to fix the display at www.AnyoneCanFixIt.com They have fast service and way cheaper than Bose.
Nov 17, 2008 | Bose Lifestyle 12 System
BOSE | Radio
have heard of this but honestly dont remember much about it as this was many years ago in car rental but if i remember it was to do with resetting the radio ,their was 2/3 settings but to set it ??something to do with audio output for classical music
Oct 23, 2008 | 1996 Audi A6
Bose Wave Radio Logo
573 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
