Question about Kenmore Frigidaire Refrigerator Or Freezer Handle 218428121 m
Kenmore model 795.78272.900 freezer fan making noise
Freezer fan making loud noise.Ice build-up on back panel.
Master_Tech
  • 770 Answers
SOURCE: Kenmore upright freezer
Where do you see the water coming from ?
Posted on Jul 21, 2008
  • 306 Answers
SOURCE: Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Posted on Nov 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Posted on Mar 22, 2009
SOURCE: kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Posted on Jun 20, 2009
  • 523 Answers
SOURCE: Kenmore upright Freezer 20.3 cu.ft has 2 switches
its a temp alarm
Posted on May 26, 2010
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Upright freezer makes a loud rattling sound, like something is loose. Doesn't do it all the time, but does several times a day.
have a look behing your drws in the freezer it has probably started to freeze and the fan that blows the cold air around will have an ice build up. The noise you hear is the fan bashing against the ice. The fan is normally situated behind the panel in the freezer section.
Hope this helps
Mar 22, 2010 | Whirlpool Freezers
Bosch Fridge Freezer KGN39V00/GB noise
Yes, it may be the fan. it might be rubbing against wires or the back panel. if thats the case you can fix it by adjusting the fan so it wont touch the wires or borders of the panel. if you see that the fan is instead rubbing ice ( if there is a ice build-up behind the panel and its against the fan) then the problem is more serious. you may need to replace the bi-metal,possible the timer, resistence and you may have the drain outlet block with food, ice,etc. good luck .
Mar 06, 2010 | Bosch Freezers
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Nov 23, 2008 | Kenmore Freezers
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore Frigidaire Refrigerator Or Freezer Handle 218428121 m Logo
57 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
