Question about Creative Labs Nomad MuVo MP3 Player
USB connection problem?
When i connect my muvo 2.0 to the computer, the computer cannot recognise it. it syas that there is a problem r sumthing.. why does it do this? I know that its the MP3 thats doing it cus other usb stuff connects fine.
5 Suggested Answers
  • 45 Answers
SOURCE: Problem with my Muvo S200
man i think i have the same problem with my device also you better go to nearby vendor or register online and ask for the warranty support from the manufacturer the i\o error signifies the device has become corrupt
Posted on Aug 06, 2007
SOURCE: need help
Try this it fix the issue
Posted on Dec 29, 2007
  • 212 Answers
SOURCE: my creative zen stone plus mp3 isnt recognised when connected by
first install all the drivers and software that came on the cd with the device. if the installation procedure asks to connect the device, connect it, if not, wait with connecting until after the install is complete and after you have rebooted the computer...
Posted on Jun 22, 2009
  • 608 Answers
SOURCE: unable to switch on
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
  • 190 Answers
ur philips mp3 player memory is infected by virus thats why it cant be detected by ur pc same prblm happens with pen drives as well.
Follow These steps connect mp3 player and restart ur pc this will help in detection.
if this doesnt work then use usb virus scan utility
this is the link:
Posted on Mar 30, 2010
0 characters
1 Points
When i add mp3 songshangs my computer
does your muvo s200 able to turn on?
if not the circuitry in your muvo s200 is deeply damage
your computers hanging because of the possibility that the circuitry of your muvo s200 is short circuit which may damage your computer also specially the usb ports...
or try to plug it in other computer if it works
hope this will do
please vote....
Jul 08, 2009 | Creative Labs MuVo S200 MP3 Player
Unable to transfer music on creative muvo v100
i have stored all mp3 player songs in my Olympia MP3 player but unable listen to songs getting an error message NO FILE but already there are 30 songs were there in MP3 player please let me know
Apr 05, 2008 | Creative Labs Muvo V100 MP3 Player
Creative Muvo V200 power on problem
My MuVo was having problems until I installed the latest firmware. The last firmware release was in August 2006. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo V200 Firmware 1.13.03.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver
Other downloads for the Creative MuVo V200 are located here.
Dec 29, 2007 | Creative Labs MuVo V200 MP3 Player
My computer still wont recognize my muvo tx fm
Plug unit in and open my computer, if it can read the unit it will show up as a removable disc, usually drive F:, copy and paste or click and drag music files into this drive to load your player. Good Luck Hope this helps.
Sep 12, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Muvo V100
Just a guess but try and plug it into the one of the back USB ports of your PC
Aug 19, 2007 | Creative Labs Zen Touch MP3 Player
File system error
hi! all,
when i connect my muvo n200 256MB, it show h: is not accesible. The request could not be performed because of an I/O device. Please help what can be done. please reply
Aug 01, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Stuck in recovery mode and i don't know what to do
I recently had a similar problem, and nothing I did helped; what I eventually did sounds pretty simple and possibly won't help ( I have a feeling that it might have been a USB port issue, more than anything). I have added the description of my problem below my 'solution'.
I disconnected the player from my PC, restarted the PC, disconnected & reconnected the battery from the Muvo2, turned the player on (just to check if it was reading the music) then turned the player off. Then (with the Muvo2 powered off) I reconnected the player to the USB cable; the darn thing was recognised immediately and was working fine...
My problem:
The player was working fine, Windows (XP Pro) recognised the device as a Muvo2 & I could transfer files no problem; I clicked on 'Safely remove hardware' and removed the player. However, when I now try to reconnect the payer Windows gives me an error message, that one of my USB devices failed to connect and that it doesn't recognise the device. It suggests reconnecting, which does nothing...
The Muvo2 screen displays the 'connected to computer' image. If I disconnect using the 'Safely remove hardware' and unplug the cable, the player display says I need to connect to my PC and run scandisk. I can't get the computer to recognise the device, so I can't run scandisk. Removing and reinserting the player's battery got rid of the 'Scandisk' message & the player worked again, but it's still not connecting to the PC.
Jan 27, 2007 | Creative Labs Nomad MuVo2 FM MP3 Player
Oct 11, 2006 | Creative Labs MuVo S200 MP3 Player
Usb connect then removes player repeatedly
have you tried to insert it at the other usb port in your pc? cause the port that you are using might be already defective try to use the other port.
Jul 27, 2006 | Creative Labs MuVo V200 MP3 Player
Creative Labs Nomad MuVo MP3 Player Logo
20 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
