Question about GN Netcom GN 9350 Wireless Headset
My headset is not working. No blue light flashing and can't hear a dial tone.
The base is plugged in, all 4 lights on the base are showing green. Blue phone and internet connection lights are not on and the headset lights are not on either.
5 Suggested Answers
SOURCE: Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Posted on Jul 16, 2008
SOURCE: The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Posted on Sep 16, 2009
SOURCE: GN 9350 Headset won't charge, blue light remains off
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
steve007morr
  • 23 Answers
SOURCE: green light keeps flashing, no connection at all
the battery is not in place correct remove case and check if its not in place by the slightest margin it will not work, or try and purchase a new headset with battery included
Steve
Posted on Oct 30, 2009
Parrot bluetooth b250 xt alternating red and green flashing lights
While device is on hold both volume buttons for 6 seconds till you hear 2 tones. Then plug in factory supplied charger for 10 seconds. Unplug a d re-pair to your device
Nov 19, 2012 | VXI Corporation Blueparrott B250-XT...
I can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
As of 2012: the button to hold is POWER.
1. make sure HS-905BT is off (hold Power till the blue light goes off, you hear descending sequence of tones)
2. hold Power to turn on (ascending tones, blue LED on) + KEEP holding Power till the blue LED flashes twice and you hear a double-beep. Device is ready for pairing.
Jun 02, 2012 | Radio Communications
How do I turn it on. Is the red showing or not showing
To turn the Explorer 240 Bluetooth headset on, press and hold the call control button until the indicator glows blue. You will hear ascending tones. The headset will then show intermittent flashes of blue. You should only see a red light when powering the headset off or if you are charging the headset you will see a solid red light. User guide is included in this link.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Aug 03, 2011 | Plantronics Explorer 240 Bluetooth Headset
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
After i try to turn it on, I get 1 blue flash and 3 short red flashes and it wont turn on.
When you turn on your headset, the blue light indicates it's on and
the three red flashes indicates a charged headsets. If it's not
turning on after that, try resetting the headset (turn off and on).
Turn it off by pressing the call control button until the indicator
glows red (you'll hear descending tones). Once off, turn it on in the same way (you'll hear ascending tones).
Jul 08, 2011 | Plantronics Hama Voyager 520 Bluetooth...
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
How to pair my blue parrot b250 with my phone lost my notes on how to pair
1. Turn headset off (panel 5).
2. Hold down the headset’s MFB until the red and blue lights
flash and you hear 2 rising tones, followed by 4 more tones.
Important: Wait for all tones and for both lights to flash. This
may take up to 15 sec. Release the MFB.
3. Follow the manufacturer’s instructions for putting your
cellular phone into Bluetooth discovery mode.
4. Wait 5-15 sec. while the devices discover each other.
When the phone discovers the headset, select “Pair” and
enter a passcode of 0000 when instructed. When pairing
is complete the headset’s blue light will stop flashing and
the phone will prompt you to ‘connect’ to the headset.
Enter “Yes” on the phone to connect to the headset. When
connected, the blue light will flash indicating that the
headset is in standby mode ready to receive a call.
USER GUIDE
Jan 03, 2010 | VXI Corporation Blueparrott B250-XT...
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Jun 21, 2009 | GN Netcom GN 9350 Wireless Headset
Headset CS50
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
1. Return the headset to the
Headset Docking Cradle
2. Press and hold both the
Speak Volume Adjust Buttons (+/-)
on the back of base unit for a
minimum of 5 seconds. The
Red Power Indicator will then
flash
3. Press and hold the Headset
Mute Switch (black button on top
of earpiece) for a minimum
of 5 seconds. The On-line
indicator (green light on boom)
will then illuminate.
4. Subscription completion is
indicated when the Power
Indicator is fully illuminated
and the On-line Indicator is
extinguished.
5. If subscription fails within 2
minutes the headset will return
to the un-subscribed state.
Aug 19, 2008 | Plantronics CS50 Wireless Headset
GN Netcom GN 9350 Wireless Headset Logo
91 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
