Question about Philips 32PF7320A 32 in. LCD Television
Tv wont remember channels...
I turn it on, go to menu and tell it to scan for channels. i get all my channels and its all good, but when i turn my tv OFF, the NEXT time i turn it on, the channels are gone! i have to REinstall them and its GETTING OLD! do i need some sort of memory device or something???
  • jordon_edmon Jan 21, 2009
    whats a small signal board? gotta talk to me like im dumb otherwise no problems solved lol.
  • jordon_edmon Jan 22, 2009
    where could i find something like that and how much do you think it would cost?
  • 54 Answers
Replace your " small signal board " ssb to a tv tech.
that will solve your memory problems
Posted on Jan 21, 2009
  • brianbuy Jan 21, 2009
    it is the digital board, your main computer, audio and video processing board
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
Insignia tv channel scan duplicate channels
the set should have in the menu a way to manually add or delete channels, consult the owner manual and or look for that feature in the sets menu.
Apr 16, 2012 | Insignia 42" LCD Flat-Panel HDTV
I have a problem to scan a local channel in Indonesia area with my lcd monitor hyundai L19T
is your lcd in english? what do you mean you ccant find indonesia on the menu? are you looking for the language or the indonesian channel? well if your looking for the language you should go the settings menu and go to language..from there try to find indonesia and enter,then the language will be indonesian..or if your wondering why you cant scan the channels on your lcd..you should try settings menu again and go to the channel set up..find auto scan and click it..then your lcd should be scanning and remembering all the channels thats been scanned,but before you do the scanning make sure that your antenna or your cable provider is connected to your tv..otherwise you wont scan anything
Jan 13, 2012 | Hyundai Electronics L19T 19 in. LCD...
Picture loss
hello,, I suggest that you go into the menu find the auto scan or auto channel setup and allow the TV`s to auto setup, this will find valid channels and tune them in, this should solve you problem, also note, after a power failure you need to rescan or re tune, it will not remember your last setup good luck
Apr 26, 2010 | Televison & Video
Kenmark 22LVD01D digital tv wont save the new channel changes. It still keeps all the channels that have not changed but as soon as you turn it off it looses all the newly scanned channels.
bring up the lcd menu then press 1471 click on ee2prom reset then do the same on the next screen
this will reset the tv and carry out first time install
Oct 23, 2009 | Televison & Video
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Tv won't scan channels when connected to cable tv
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
May 01, 2009 | Televison & Video
No channels set on tv
You have to go into the tv menu , set it for cable and then scan for channels then it will remember them.
Feb 03, 2008 | Televison & Video
32 astar tv
the tv remote has what you call a menu button press it and the menu will come.if you are using a universal remote you wont be able to get any menu most universal remote dont have menu features.if you do not have the originald remote press channel up and down together on the front panel of your tv and you can use the remote to acess what ever you want or the volume up and down button on the front panel of your tv.good luck.
Apr 01, 2007 | Astar LTV-3201 32 in. LCD Television
Philips 32PF7320A 32 in. LCD Television Logo
260 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
