Question about HP Photosmart D7160 InkJet Printer
Will not recognize new yellow ink cartridge
I have only printed less than 200 prints on my D7160. It will no longer accept new yellow (hp factory new) cartridges. After trying 7 brand new hp cartridges it keeps telling me that I must replace the yellow cartridge to print. I no longer cannot even print in black & white. This renders my printer useless, HP cannot help me!!!
  • 3 more comments
  • jalacroix Jan 21, 2009
    Won't recognize new yellow cartridge
  • jacob9002 Feb 01, 2009
    LOL jalacroix, that is what I am pretty much coming to terms with my D760. JUNK. But first I will take it, drop it on the floor, hook it back up and just see!!! rofl...
  • Anonymous Feb 19, 2009
    I too have purchased multiply yellow ink cartridges and it just keeps telling me I need to replace the yellow ink cartridge and that I will not even be able to print in black any longer
  • ahparas Feb 20, 2009
    I too have the same problem, yellow cartridge always displays empty. Purchased two more yellows, still the same problem. Will only print in black. Did a self diagnostic test and it shows on the ink delivery system information that the ink status 1: Reserve and the other colors show OK. Ink level: 0% and the other colors show a higher percentage. What is it with the yellow? HP's technical staff is useless. They tell me to contact service and it is a hardware problem. I've been searching for myself and found a master reset instruction, but can't open the right side of the printer? Any suggestions. Next step is to junk this and all future HP products.
  • Anonymous Mar 02, 2009
    My problem is the same as above. Nice the printer lasted a year out of any waranty & it quits printing 1 color & wont let me print in black any either. JUNK
I junked it!
Posted on Jan 30, 2009
    Problem Solver:
I had same problem with yellow cartridges. Staples said it was bad printer head. Extended warranty replaced printer with a defective one, then replaced that one with one that will only print thru the computer and will not light start button or screen. I can't use the buttons on the printer. Tired of shipping printers so will never buy another HP product.
Posted on Mar 13, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
Ink display will not reset upon installation of new ink cartridges
POSSIBLE PROBLEM: In the passed, whenever I installed ink cartridge in a HP, the computer inside the printer audits the cartridge(s), and if it isn't or wasn't HP Brand cartridge(s), it wouldn't accept or recognize the cartridge(s). I hope this helps.
Oct 15, 2009 | HP Photosmart D7160 InkJet Printer
Printer wont recognize a new ink cartridge
Let's hope it is only some dirt or oil on one of he many little electrical contacts, in the printer, that touch the back of the ink cartridge, which can be cleaned with a Qtip and denatured alcohol. if that doesn't work, you probably have damaged the contacts somehow, and will need a repairman. PS- your lucky- some printers won't even print in black if there's a problem with a color cartridge.
Sep 12, 2009 | HP Photosmart D7160 InkJet Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Yellow ink cartridge will not print
The print heads must be bad. I had the same problem. Still under warranty and HP replaced printer with rebuilt unit
Feb 23, 2009 | HP Photosmart D7160 InkJet Printer
I have a hp psc 1210 all in one,it is playing up with print outs, is it possible for me to replace the print head on this model Rick
HP printers use cartridges that ARE the print head. On occasion, the cartridge could be defective...especially if they are the remanufactured type. Try replacing your cartridge with a new HP cartridge.
May 29, 2008 | HP Office Equipment & Supplies
HP Photosmart D7160 InkJet Printer Logo
660 people viewed this question
Seeker5211
Seeker5211
