Question about Ruud Central System Air Conditioner
Ruud heatpump with electrice heat backup
No heat when set on 'EM'. The fan will go on but no heat. The compressor does not come on but that is a good thing. Yes there is 220 to the furnace.
    Novelist:
  • 88 Answers
Thanks for you question, I am mr.grzz,
with the unit in em heat, only the electric strip heat will come on, or should, if you are not getting any heat from the heat strips, then you probably have a bad sequencer, these bring on the heating strips, you will more than likely have to replace the sequencer thats bad, sometimes its burned out on top, you might be able to see it, you could tap the sequencer with a plastic pen to see if it is sticking, does the fan come on when in em heat ? if not you may have a bad circuit board, please check your filters as this is very critical for the system to function right, well good luck, hope I was helpful, thanks again, mr.grzz
Posted on Jan 21, 2009
  • 163 Answers
Hi!! please!!check your heating sequencers or your heating element coils.good luck..
    President:
  • 1,214 Answers
Sounds like one or more of the following -
1) the thermal fuse for each of the elements have melted
2) the elements themselves have broken and opened
3) Heat sequencers have failed
4) One or more fuses inside the heater have failed (if fuses were installed from the factory.).
Items 1 and 2 are indications of poor airflow through the unit for some reason (dirty filter, closed vents, dirty evaporator/buildup of dirt/dust on evaporator.)
Should I use the em heat setting for every day operation?
Not if the thermostat is controlling the room temperature to its setpoint. Emergency heat is for when the heatpump is in defrost or doesn't work and you need backup heat.
Dec 09, 2016 | Heating & Cooling
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
I have arcoaire thermostat (not digital) with Comfort Air FBA series system, vintage 1998. The bottom of thermostat has selections: ''EM Heat'' ''Heat'' ''Air'' ''Off''. I am not original owner. Q. Should...
yes go into electric heat for awhile. sometimes a heatpump will run constantlly when temps outside are not high enough./em heat mode untill temps rise or unit recovers.your unit should of gone into hot-gas defrost this maybe what your hearing. but remember electric heat is expensive to operate go back to your heatpump mode after system has a chance to recover.
Jan 31, 2010 | Heating & Cooling
I understand a Hunter44550 will not support the heat strips in my rheem heat pump
That is correct, you need a heatpump thermostat, it will have a EM heat setting on it
Jan 05, 2010 | Hunter Fan Company 5/1/1 Programmable...
Tempstar phad42n1k1 heaters come on in ac mode and compresor or fan wont run in heat mode. was able to make heatpump go in defrost mode and compressor runs.
sounds like u have the thermostat wired wrong or bad wires i would check that first make sure you have the wright thermostat
Jan 05, 2010 | Ruud Central System Air Conditioner
When the heatpump is on the condencer fan comes on. this a goodman package unit
yES, THATS TRUE,ALSO THE COMPRESSOR TOO. TO REMOVE HEAT OUT THE OUTSIDE AIR DOWN TO 40* THEN THE BACKUP HEAT SHOULD KICK IN OR ITS CALLED THE EMERGENCYHEAT.
Dec 02, 2009 | Heating & Cooling
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
Ruud Central System Air Conditioner Logo
185 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
