Question about KLH Audio Players & Recorders
Fuse blows when powered on . KLH E-10DAW
Recently noticed the subwoofer was not working. I found that the fuse in back had blown. When I replaced the fuse it again blew. It is very possible that we experienced some type of electrical problem in the form of low voltage or a power surge. Any suggestions?
  • 4 Answers
Hi, you can get the fuse at Polk Audio. 800-377-7655. You can talk to technical, too.
Posted on Jan 22, 2009
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 13, 2010 | KLH ASW10-120 Subwoofer
KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Dec 26, 2009 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
Burning smell
The amps do have issues that is for sure - That is where I step in - I can repair your amp and make it so it won't burn up (catch on fire) again. When the amp goes it burns a hole in the board - but it can be repaired. I have done several hundred and all customers are happy :) ... Look for my add here and also on ebay
May 12, 2008 | KLH ASW10-120 Subwoofer
Subwoofer no longer produce base sound
Master witch is blown. Also the frequency control swithe is probably gone. No replacement parts available. contact KLH at 818-767-2843
Dec 03, 2006 | KLH ASW12-200 Subwoofer
358 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
