Question about JVC Audio Players & Recorders
Tone arm won't swing into play position JVC ALF350BKX Turntable
4 Suggested Answers
  • 6 Answers
SOURCE: SL-BD22 Stops as you move in the tone arm
I am not particularly familiar with this model but if you have to have a disk on the turntable in order for it to run (a safety for stylus protection perhaps) why not just put on a disk and see? This feature would be a fairly complex one (photosensor perhaps) and I would not expect to see it on an inexpensive piece. Likely as not this has to do with a switch inside probably activated by a cam wheel (used in the raising of the arm at the end and returning the arm to rest) that is not set right. This cam or some link to it may have a problem which need to be addressed. All this I grant is speculation which would become clear if I saw the unit but unfortunately that is not an option. As to whether its a piece of junk, I wouldn't buy it unless I thought I could make it work. Paying any real amount of money to another to fix it makes little sense to me.
Posted on Jul 03, 2009
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
  • 13 Answers
SOURCE: Need a manual for a Realistic Lab-2100 Turntable
look on ebay
Posted on Feb 24, 2012
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
Bic 960 turntable tonearm drop position
The service manual shows the adjustment for the tone arm set down position is accessed from the top of the unit. It is in front and to the right of the pivot point of the tone arm. The other problem is something that I can not diagnose here but I am providing a link to the service manual. You will have to set up a free account with vinyle engine. The service manual is a free download.
Jan 01, 2018 | Audio Players & Recorders
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
Nov 09, 2011 | Crosley 0187SST Turntable
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
I have new Prolectrix turntable USB Direct and tone arm leaves record before end of playing record. Hope you can help. Thanks
Turning the return position adjustment (the flat black-headed screw next to the tone arm) a little clockvise will probably fix your problem.
Jul 06, 2008 | Audio Players & Recorders
19 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
