Question about Generic Hiteker 37" Class LCD 1080p 60Hz HDTV, MSAV3719-K3
Vertical green line down the middle of new Hiteker 37" lcd television
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: have a hiteker 37" how do you change from 480p to 1080p
The set should do this automatically depending on what is connected for signal and where.
Posted on Dec 06, 2012
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Have a hiteker 37" how do you change from 480p to 1080p
Dec 06, 2012 | Generic Hiteker 37" Class LCD 1080p 60Hz...
I have a 37 in sharp lcd tv. it has a black line in the middle of the screen. looks like it burnt into the screeen. is this repairable?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help.....
Jun 22, 2010 | Sharp Televison & Video
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
There is a vertical line of dead pixels on the right side of the screen.
If the line travels from the top of the screen to the bottom, try disconnecting the Tcon LVDS lead. The Tcon is located in the top middle of the LCD rear. Disconnect the LVDS from the Tcon by pushing in the outer lobes. Clean the contacts on the LVDs lead and reinsert. If this doesnt cure the fault, disconnect the ribbons from the Tcon connecting the LCD and clean and reinsert. If this doesnt cure the fault you have a faulty LCD.
If the vertical line doesnt travel from top to bottom of the LCD, the LCD is faulty (LCD matrix buffer).Hope this helps :)
Feb 17, 2010 | LG 37LG30 37 in. LCD HDTV
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit ctechnicians.com
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Generic Hiteker 37" Class LCD 1080p 60Hz HDTV, MSAV3719-K3 Logo
29 people viewed this question
Top Generic Televison & Video Experts
richie46
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
