Asus p4s800 acpi bios revision 1005 - Computers & Internet
5 Suggested Answers
  • 489 Answers
SOURCE: Computer will not start,audible alarm every 5 seconds
Check your power supply. A beep every 5 seconds or so generally indicates a problem with power supply voltages.
Posted on Apr 09, 2009
  • 300 Answers
SOURCE: Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
Posted on May 13, 2009
map9966
  • 2351 Answers
SOURCE: ASUS CUSI-M ACPI BIOS Revision 1007
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
Posted on Jun 05, 2010
gotgeek2
  • 565 Answers
SOURCE: Motherboad ASUS P4S533 ACPI bios
Yes, just install a PCI card like this one:
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=3331701&CatId=511
Posted on Nov 13, 2010
Testimonial: "Thank you very much for the information. it was very helpful. Thanks again."
I have lost my asus P4S533MX driver cd
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Sep 23, 2012 | Computers & Internet
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
Mother board failed and somehow the bios got cleared where do i get the bios dont have the disks
download the Bios Driver From here:
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P4S800-BIOS-1011001.shtml
Jan 15, 2011 | ASUS P4S800 Motherboard
HOW CAN I GET MOTHER BOARD SOFTWARE OF ASUS P4GE MX ACPI BIOS REVISION 1005
pliz help me i want to download mother board installer for asus p4ge-mxacpi
Sep 01, 2010 | ASUS P4PE-X Motherboard
Looking sound driver installer to my computer asus p4pe acpi bios revision 1005
Go to asus.com and enter your info there. You will be shown a page with all the pertinent drivers for your computer. Download your audio driver and then install it. If you still don't have any audio after that then your integrated sound card may be burned out. You can easily fix that by getting a PCI sound card.
Mar 19, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
Thanks
May 13, 2009 | ASUS P4PE-X Motherboard
Apr 09, 2009 | ASUS Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
