Question about Razor E100, E125 & E200 Electric Scooter Front Wheel
Need help putting the rear wheel back on the e200 razor electric scooter
I took the wheel off to fix the flat tire now i want to put the rear wheel back on the scooter
3 Suggested Answers
  • 38 Answers
SOURCE: How can I put chain back on my E200 razor electric
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Posted on Aug 18, 2010
  • 38 Answers
SOURCE: re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
How i can pump the weels on the back
Hi, you need to take the end-cap off of the right side of the handle bar. It is a black cap/plug that pulls out. You will see a black plastic piece that's about 3" long. Pull that out of the end cap. This is the extension that is screwed on the the air valve. Just place through the hole in the rear sprocket and thread on, and fill the tire with air. When done, unthread it and replace back into handle-bar end-cap and reinstall the end-cap. It only took me 4years to figure that out!
May 09, 2014 | Razor E200/300 Electric Scooter Battery
Where can I buy a new battery charger for my E200 Electric Scooter
Wheel Gears provide the best Review of the Electric Scooter; customers can view the multiple Reviews different Electric Scooters and they have a chance to select best one. http://wheelgears.com/
Wheel Gears
Dec 11, 2012 | Razor E200/300 Electric Scooter Battery
I need instructions on how to replace the rear tire on a razor electric scooter model E100
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Jul 27, 2010 | Razor E100 Electric Scooter
Re-assembling a E200 rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
Your done!
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
How to fix flat tire.
Hi:
I have a rascal 3 wheel chair and the tire is flat on back, how do they come apart for repair, thanks.
Leroy
Mar 28, 2010 | Razor E100 Electric Scooters Red
What do you do when ur razor e200 electric scooter stops working?
First try charging the battery, if that doesn't work then replace the batteries with replacements from razor.com. This should solve your problem
Jan 15, 2010 | Razor E200/300 Electric Scooter Battery
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor E100, E125 & E200 Electric Scooter Front Wheel Logo
54 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
