Question about Samsung RL38SCPS Bottom Freezer Refrigerator
Cannot get bulb cover off RL38SCPS to change bulb?
Bulb has gone but cannot remove the cover to replace it despite following instructions in the manual?
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: he bulb has gone and the manual said its needs an engineer to replace it? seem crazy any ideas?
other expert:model seems to be right at top of page RL38SCBP1XEU Bottom Freezer, ha ha.
Posted on Nov 04, 2012
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
Light bulb has gone, can't see where it is located or how to change the bulb
Do as follows. Do not connect the microwave oven to mains while doing the following activities. Even the accidental switching ON will harm you from the microwaves. Open the top cover by unscrewing side screws & the screws at the back. Lift the top cover by tilting upwards from rear end. Remove the wave guide of magnetron & there you will find the bulb. Wave guide is rectangular small ducting (pipe enclosure) to guide the microwaves from the magnetron.
Sep 17, 2011 | Microwave Ovens
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
Change headlinght bulb
SECTION 417-01: Exterior Lighting 2005 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/14/2005 Headlamp Bulb adobe.gif Printable View (327 KB) Freestyle, Five Hundredn0035265.gif
Item Part Number Description 1 — Headlamp bulb electrical connector (part of 14290) 2 13N021 Headlamp bulb
Item Part Number Description 1 — Headlamp bulb access cover screws (6 required) (part of 13006) 2 13N019 Headlamp bulb access cover 3 — Spring retainer (part of 13006) 4 13N021 High intensity discharge (HID) bulb 5 14A411 HID bulb electrical harness 6 — High beam bulb electrical connector (part of 13006) 7 13N021 High beam bulb Removal and Installation
ani_caut.gif WARNING: The headlamp bulb contains gas under pressure. The bulb may shatter if the glass envelope is scratched or if the bulb is dropped. Handle the bulb only by its base. Avoid touching the glass envelope. Failure to follow these instructions may result in personal injury.
NOTE: The headlamp bulb should not be removed from the headlamp assembly until just before a new bulb is installed. Removing the bulb for an extended period of time may affect headlamp bulb performance. Contaminants may enter the headlamp assembly where they can settle on the lens and reflector. Never turn on the headlamps with the bulb removed from the headlamp assembly.
NOTE: Make sure the headlamp switch and ignition switch are in the OFF position.
  1. Rotate the headlamp bulb 1/8-turn counterclockwise and remove the headlamp bulb.
    • Disconnect the electrical connector.
Montego
  1. Remove the headlamp assembly. For additional information, refer to Headlamp Assembly — Five Hundred, Montego in this section.
  1. Remove the 6 screws and the headlamp bulb access cover.
Montego high beam bulb
Montego HID bulb
  1. Release the spring retainer and remove the HID bulb.
All vehicles
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=n920901&c35=wsm%2cheadlamp%20bulb%2cs5f%2c417-01%2cremoval%20and%20installation&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 02, 2010 | 2005 Ford Five Hundred
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How do you properly remove cover to change
The directions for changing the headlight light bulb in all cars are near to same . but all car models are not the exact same, so there may be a few differences based on your particular car. But this.instructions may properly guide you about the directions to replace the head light bulb in your car.
The instructions are as follows :----
1) First of all open the hood of your car and put a spot light or flash light onto the back of the headlight. Look towards the far corner side of the hood, the headlight is located in a space mounted to the far sides.
2) In some of the car models there is a back cover for which you will require a screwdriver to unscrew the back plate to reach to the bulb. properly locate the screws and unscrew the screws using the proper size screwdriver.
3) Then remove the back plate.
Note: In some car models there will be a wiring component connected usually by plastic clips, so detach the plastic clips and then pull wiring to the side. Then remove the back plate.
1) Remove the Old Light bulb which will be easily visible. Then remove old light bulb by screwing it to the left slowly and carefully.
2) You can get the new light bulb from local auto store and purchase the bulb exactly that matches the one your car model .
3) Then insert the new light bulb in reverse by screwing to the right, and secure in place confirm bulb is properly connected and fitted and not remained loose.
4) To test whether the bulb is properly connected. Just try turning on headlights and make sure it lights up.
5) Then plug wiring component back in if your model has that.Then put backplate back in place , then insert the screws back in and screw in with screw driver tightly.
6) Then close the hood properly and check out head light again.it will work properly.
That means your work is done.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 20, 2010 | 1996 Mercedes-Benz C-Class
How to change a headlight bulb
The procedure is given below in step by step. Hope it helps..
Drivers side:
  1. Remove plastic cover on rear of headlamp by pushing down on long wire clip.
  2. Pull cover outwards and downwards to release the two clips on top of cover.
  3. Remove wiring connection from rear of bulb.
  4. You will now find that a mirror and torch will come in handy.
  5. Using the mirror you will see that the bulb is held in place with a spring clip that locates under a metal lug on the headlamp.
  6. Push the clip so that it releases from the lug and swing the clip away from the bulb.Remove old bulb.
  7. Insert new bulb making sure the locating tab is in the correct position.[Use the mirror to check].
  8. Replace spring clip.
  9. Reconnect electrics.
  10. Replace rear cover and long wire clip.
Passenger side:
  1. Little more difficult.Remove battery cover and follow the same instructions as for the drivers side.Not so much room to work this side though.
  2. Do not touch the glass parts of the bulbs whilst changing them and if you do clean the glass with metholated spirits before fitting.
Jan 15, 2010 | 2003 Ford Focus
Replace front headlight
Headlights Removal & Installation WARNING
Halogen bulbs contain a gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments.
To help avoid personal injury:
  • Turn off the headlamp switch and allow the bulb to cool before changing bulbs. Leave the headlamp switch off until the bulb change is complete.
  • Always wear eye protection when changing a halogen bulb.
  • Handle the bulb only by its base. Avoid touching the glass.
  • Do not drop or scratch the bulb. Keep moisture away.
  • Place the used bulb in the new bulb's carton and dispose of it properly. Keep halogen bulbs out of the reach of children
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • LH and RH engine under covers
    • RH and LH Front fender liners
    • Front bumper cover
  3. 2 bolts and disconnect the connectors
  4. Headlight assembly by pulling it forward
  5. To Install:
    1. Install or connect the following:
      • Headlamp assembly
      • 2 bolts and connector
      • LH and RH front fender liners
Jul 25, 2009 | 1998 Toyota Camry
How do I change a headlight bulb in a 2003 focus?
Drivers side: Remove plastic cover on rear of headlamp by pushing down on long wire clip.Pull cover outwards and downwards to release the two clips on top of cover.
You will now find that a mirror and torch will come in handy.Using the mirror you will see that the bulb is held in place with a spring clip that locates under a metal lug on the headlamp.Push the clip so that it releases from the lug and swing the clip away from the bulb.Remove old bulb.
Passenger side:Little more difficult.Remove battery cover and follow the same instructions as for the drivers side.Not so much room to work this side though.
Oct 26, 2008 | 2003 Ford Focus
We have a Neff B1432 Single Oven. The interior light has gone and needs the bulb changing. The instruction leaflet says to - Unscrew the lamp cover by turning anti-clockwise. It does not move . Help !
they are often very stiff due to crud burning on. use mole grips and there is a risk you will break bulb cover but that is not the end of the world.
make sure you use a heat proof bulb as a replacement
Sep 30, 2008 | Kitchen Ranges
Samsung RL38SCPS Bottom Freezer Refrigerator Logo
317 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
