Weil Mclain heater makes a whistling sound when ift first starts up
The gold GSa 105 BTU makes a whistle noise when first heating up
  • Renna Jan 10, 2013
    The burners are clean I used a pipe cleaner to clear all nozzles and vacumed it and the burners, I always worked on cars and sounds like a leaking gasket however it stops after the boiler stays on to heat the water
hotuna
  • 288 Answers
SOURCE: loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Posted on Dec 28, 2007
jbjaxiis
  • 95 Answers
SOURCE: i have a high efficiency
I would have the the burners cleaned, you may be hearing a clog starting to form at the valve on the furnace.
Posted on Jul 06, 2008
  • 2920 Answers
SOURCE: High pitched whistle
can u please rate my help? thanks you
Posted on Aug 28, 2008
emissionwiz
  • 76109 Answers
SOURCE: Engine makes a whistle sound.
It is the air bypass valve that makes this noise
Posted on Oct 05, 2008
mark_bown
  • 37 Answers
SOURCE: loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Posted on Jul 13, 2009
Whistling noise after 5 minutes of heating. Heater is less than 3 months old! What can be the cause?? New gas line, 1.5" as recommended.
I changed the gas line from a small 1" to a massive 2.5" plastic line and NOW I have the whistle! Anyone that knows how to fix or diminish, PLEASE REPLY...
Jul 22, 2015 | Jandy LXI400N Lxi Pool & Spa Heater -...
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
Whistle noise
A whistling noise can be generated by an alternator at high RPM's and indicates a slip ring brush problem or a diode failing . It resembles a frequency whistle.. IT may also be from a leaking gasket and a partially blocked exhaust system from a failed cat converter and at speed and power, the exhaust gas is forced out the hole
Dec 26, 2013 | 2012 Acura TL Base Sedan 3.5L V6 6-speed...
Why does my Big Buddy Mr. Heater make a whistling or humming noise?
mr heater makes a whistling sound as gas escapes around the gasket of the ceramic heating elements, that is ,all around the outside edges of the ceramic heating elements.
You can find out exactly where the gas leak is , by pressing down on the outside edges of the ceramic elements with a big, long
slotted (flat bladed) screwdriver while mr heater is running and hot.
The screwdriver needs to be long enough so that you dont burn your hands [the longer & bigger the screwdriver, the better] & it does not hurt to wear heavy gloves too, because it gets very hot, very fast in front of mr heater.
The thicker the blade of the screwdriver is, the less chance of damaging the ceramic heating element because a thick bladed screwdriver will not concentrate all the pressure in just 1 tiny point.
You are not trying to crack the ceramic with a wood chisel.
Dont press down so hard that you break the ceramic heating element, start by pressing down gently and gradually increasing pressure until you notice a change in the whistle or sparks comming out of the heating element as loose carbon deposits
come out of the heating element and burn in the propaine flame.
When you press down on one edge ,the other opposite edge may come up slightly, resulting in loose carbon deposits escaping and burning as sparks.
also, you may not be pressing at the spot where the gas whistling is comming from and will need to move the screwdriver flat blade around the edges, here & there, to test for the effect of pressing down.
When you press down on the outside edge where the diamonds stop, while mr heater is whisteling, the whisteling will stop & mr heater will run quite. Sometimes, just pushing down with the screwdriver will stop the whisteling ,for a while,and maybe a good long while.
The big pain in the **** solution is to put a new gasket around the
ceramic heating elements, but there is no guarantee that the new gasket will not whistle.
Its a big ,nasty job, which I would rather not do--so I just push down with the screwdriver, to temporarly stop the whisteling, I guess it depends on how much the whisteling annoys you, as to if you want to go thru all the effort & expense of changing out the gaskets, without knowing if it will still whistle when you are done.
Im just a diy guy that has 3 big buddys I keep going for 4 yrs now.
I took one apart to look 4 the cause of the gas whistling, and then put it back together. Funny,it stopped whisteling & that was 3 yrs ago. I didnt put in any new parts.
It may help ,a lot ,to increase the pressure with which the Mr heater ceramic is pressed down against the gasket material.
This is accomplished by a heavy stainless steel wire that runs behind the ceramic heater element and goes through sheet metal
tabs on each side of the ceramic mounting frame.
You can bend the wire and the tabs,but only a little bit, and be very careful not to break the tabs because the tabs are not repairable, to increase the downwards pressure of the ceramic element against the gasket material. This may stop the gas whisteling--
its a try & see thing, a finicky adjustment, that sometimes works
& sometimes does not and sometimes, after a week or two, the ceramic might reseat itself against the gasket material and the whistling stop. Mine did stop whistling, but not until a couple of months after i did the job, due ,i think to reseating of the cermic against the gasket material. its try & see thing.
also ,a gas tank that has higher than average gas pressure may start gas whistling up but the whistling will stop after you have burned up the higher pressure of the propaine.
Jan 06, 2013 | Mr. Heater Big Buddy Heater
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
Yesterday I had my heater converted fro LP to Natural gas (technician replaced orifice). Now heater makes loud whistling sound when burner is on. Stop making noise when heater is turned off and only blower...
The wrong orifice was installed. Sta-Rite changed their blower configuration 3 years ago. Heaters older than that have a flat orifice that works with the older style blowers. Newer heaters are equipped with a tapered orifice. Mixing a flat with a new blower causes whistling. Mixing a tapered with an old blower causes whistling. Good luck!
Nov 17, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-rite 222 r2d2 looking heater has a high pitch wine when its heating, i believe it has something to do with the air gas mixture, how do you fix this? Thanks.
this whine could also be coming from the gas valve itself. It is possible for the blower to make this noise as well. Make sure everything is in place and no hardware is missing, IE. screws, etc..
Nov 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Intermediate whistle
sounds like you have dust or spider web in one of the burner tubes. turn power off to unit and clean the burners especiaally by the nossles
Nov 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
