Question about Oreck Vacuums
Xl9100 bag removal
How to remove and clean the bag
3 Suggested Answers
SOURCE: Oreck XL9100
Posted on Oct 06, 2008
small6363
  • 18424 Answers
SOURCE: how to clean out the bag compartment above the filter cup
what make is it ?
Posted on Jan 01, 2013
How do I remove and replace the inverted bag filter?
Inverted filter bags can be tough to remove. The best way is to grab the bag closest to the top portion where it attaches to the canister. The bag is locked in place by a metal rings that presses out. You want to grab a portion of the bag (some bags have a holder tab) and pull towards the center. The goal is to make a C shape of the ring that is holding the bag in place. Once the bag collapse into a C shape, the bag can be removed and cleaned or replaced. The same technique is best for re-installing the new or cleaned bag.
Check out our website if you need replacement parts or you have more questions.
NuTone Central Vacuum Systems and Replacement Parts
Don't forget to visit and like our Facebook page https://www.facebook.com/QualityHomeSystems
Nov 05, 2015 | Broan-NuTone CV570 Central Bagless Central...
How do I remove outer bag of oreck vacuum cleaner XL 9000W and how do I clean it? Removable bag broke and outer bag filled up with dirt.
If there is a bag dock on it, seperate large part of bag dock from smaller one, by squeezing bottom of bag dock to release tabs from larger one. Pull smaller part of bag dock apart and off of vacuum. Bag will now release from hole. If there is no bag dock, there is a metal piece around hole that is holding other bag on.
Jul 08, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I have a clog in the vacuum line that comes out of the face that runs to the vacuum tube to the bag
To check for blockage in the fan housing, remove the bag assembly. Grip the lower bag housing and turn it counterclockwise for removal. If it has not been removed regularly to clean out debris, it may be hard to remove. Insert a screwdriver between the housing and the motor for leverage. For easier installation, wet the seal on the motor outlet before re-installing the bag assembly. Remember that the motor will not run unless the bag housing is fully attached.
Feb 13, 2011 | Kirby G6 Bagged Upright Vacuum
I need to remove the outer bag from my Kirby upright. The inner bag was not attached and there is mung everywhere.
In order to remove the outer jacket from your Kirby do the following.
Detach the top bag clip from the handle support. There is a plastic piece, just below the outer jacket, called the mini emptor. Turn it to the right to remove the entire bag assembly. Removing the outer jacket is dificult and even harder to put back on so this is what I would do.
Unzip the outer jacket as you were going to change the bag. Remove the paper bag. You will then see a long black tube, that has a 90 degree elbow at the top. That elbow is attached to the inside of the bag with a snap type strap. Remove the strap, then you will be able to move the tube, while you clean out the inside of the bag. When finished put everything back where it was.
Apr 28, 2010 | Kirby G4 Bagged Upright Vacuum
The Intelliclean function isn't working properly. The indicators illuminate when I switch Intelliclean off, then on again, but the indicators are not changing (nor the power level) when I vacuum dirty...
I was having the same problem with my Intelliclean and I read somewhere on the internet that I should undo the bag, clean in the area where the bag attached to vacuum. When I took bag off, something was stuck there and after I removed it, everything worked fine. I think you need to clean the sensor and check your bag.
Dec 16, 2009 | Kenmore 31913 Progressive Direct Drive...
My vacuum puts out stinky air
We put small moth balls in our bag when we change it.
Jan 04, 2009 | Bissell 3522 PowerForce Bagged Upright...
Cleaning Bag holder for Kirby G4
Take the ring from the bag re-move bag and put in a small bucket of water and let soak for about 1 hour and than remove rinse and let dry on a long slim container or counter.
Nov 27, 2007 | Kirby G4 Bagged Upright Vacuum
Removal of Outer Bag for washing
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEANING-THE-KIRBY-VACUUM-OUTER-CLOTH-BAG_W0QQugidZ10000000003719865
It should be helpful. :0)
Marci
Oct 04, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
42 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
