Question about Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer
Zebra monitor status pause - Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer
2 Suggested Answers
  • 15 Answers
SOURCE: Hi, My name is Hakan and I'm having trouble
If you are using a colored ribbon it might be too transparent for the ribbon sensor to read. Re-calibrate the ribbon sensor.
If you're using black ribbon and you're sure that it's loaded properly and the sensor isn't being blocked, then print a sensor profile and re-calibrate the sensors if necessary.
Posted on Mar 09, 2010
All the light on the control panel are "on" status & "status screen" see nothing. M/C can not work completely.
Try defaulting the printer: with power OFF open the printhead, remove the media, and hold the PAUSE and FEED buttons in. Power ON the printer. Keep holding the PAUSE and FEED buttons until the green DATA light flashes. The printer will be defaulted and returned to all factory serttings. If this doesn't clear the problem you most likely have a bad main logic board.
Sep 02, 2011 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4M printer error
Did you try disconnecting it from the power for a few hours?
Mar 17, 2008 | Zebra Z4M Printer
Zebra 2844 Printer was fine...unplugged USB then plugged into a different port on the same computer now it won't print. Says error in the printing status. It is not offline or paused.
This is due to windows which has attributed a new virtual usbport.
Go to the printer port and try another one (the last one for example)
Jul 31, 2011 | Zebra LP 2844 Thermal Printer
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
Hi, My name is Hakan and I'm having trouble with an ZM 400 label printer. My ploblem is that I get Out of Ribbon, Pause in Zebra status Monitor. What can be the problem?
Mar 03, 2010 | Zebra 203DPI Printer
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
Feb 24, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra 4m printer. Turn on and pause and error
You have a bad logic bd and it needs to be replaced our repaired.
Rory
Dec 20, 2009 | Zebra Z4Mplus Label Printer
Zebra S500 not sensing media
download the driver www.seagullscientific.com
recalibrate media, if necesseray Reset to Factory defult.
Apr 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra 170 xi labela are printing on top of each other
Don't forget to rate this.
You can download Zebra manulas from here. https://www.zebra.com/id/zebra/na/en/index/service_support.html here is a section of the calibration you require. Sorry it will not allow me to attach. i think issue with site usage.
Anyway press PAUSE to pause printer. Then find & press CALIBRATION, it will ask when you want to calibrate either at power up or after the print head is open & closed. I would select Power up since when you change lables out you should do so with printer off.
Good luck, post any questions to this & also rate it.
Feb 04, 2009 | Zebra 170Xi II Thermal Printer
Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer Logo
43 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
