I have a RED H letter appearing on one channel and the alarm sound. Restart both manually through replugging cables or digitally restart button cannot cure the problem. What should I do?
This is newly installed CCTV system a friend installed for me but the H.264 DVR user manual has very limited information. I know Red H means the system cannot recognise the HDD. I tried successfully restarting it the first time by click on restart on the monitor section of advanced set up; but the problem keep coming back. It won't start the second time and I had to manually unplug and replug all the cables. Now this time, nothing works. What should I do?
techman
  • 3130 Answers
SOURCE: No Power
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Posted on Jun 18, 2006
cheebster
  • 39 Answers
SOURCE: harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
Posted on Jul 10, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
SOURCE: Power on problem
Well this helped me find the relay but I found that after i pulled it off the board that it has some corosion around the metal prongs that hold it to the board. Could not get the relay open to do what is posted above , tryed opening it several times. Not sure if you are supposed to open it but could someone let me know. I am scraping around the prongs to get the corosion off hoping it will help but might just replace it alltogether. Further info on how to open the relay to do what is posted would help, I would appreciate any help, plzzzzz! :)
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
How do I restart an iPod touch fifth generation
  1. How to restart
    1. Press and hold the Sleep/Wake button until the red slider appears.
    2. Drag the slider to turn your device completely off.
    3. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
Restart or reset your iPhone iPad or iPod touch
Feb 23, 2015 | Audio Players & Recorders
Reprogramming channels
you can use the user manual, if none you can manually reprogrammed every channel. just go to set up menu then go to channel set up the select manual fine tuned.you can use the channel up/down button then the volume up/down button to search every channel program.
Mar 24, 2013 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
Itouch displays "disable connect to iTunes" how can I restore it?
Restart iPod touch
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
If your device does not turn on or displays a red battery icon, try recharging next.
Dec 02, 2012 | Audio Players & Recorders
Blackberry 8310 does not sync with computer
CLICK ON OPTIONS .. SELECT USB AND CLICK on detect button . through desk top manager. the pin should be appear. on the down left side of desktop manager. if msg appears. no device found. go to Control panal . phone n modem options. click on the center tab of modems n remove any STANDARD MODEMS installed there unplug the cable n replug it back .. it ll be done . else try restart.. n dtm ll pick up the phone.
Feb 22, 2010 | RIM BlackBerry Curve 8310 Smartphone
Screen has black box with greek letters on channel
If you put the TV on CH 3 and use a VCR (if available) to change channels you'll know if it's the TV or cable channel (sound like the channel)
Oct 05, 2009 | Televison & Video
Disalarmed - cannot now reset, no alarm
Drop down the dash and locate the alarm module(generally a black box) find two thicker wires going to or from the ignition. at the ignition end check to see if these two wires are attatched to a wire coming from the ignition that has been cut and joined to the two alarm wires ,if so cut them and rejoin them,this will get you home.Then go to a tech.
Apr 10, 2009 | Vehicle Parts & Accessories
Zmate mp3 player confusing
The A-B music is the repeat button.
Press the first time and you set the start point. Press it again later in the music and you set the end point and for that time on the player just plays from start point to end point and repeat it again. To remove the repaet option just press the A-B button once again. The lock button is to lock all the control buttons so that you don't accidentally press then while in the pocket. To put the music is no secret just insert the mini-usb cable in the zMATE and the computer and it should detect it as a usb drive in the next available drive letter. (if you have a network drive letter in the next available letter it will not appear and you must change the letter in the manage computer system, of course this is for windows systems)
Dec 28, 2008 | Dane-Elec TA-SD0512-D MP3 Player
27 people viewed this question
 Grubhead
Grubhead
