Question about Toastmaster Kitchen Appliances - Others
Toastmaster Toaster Oven 391B ..makes toast ok, oven doesn't work
Oven fails to warm when dial is used. Pilot light comes on. Broiler setting also non-functioning. Toast/bagel function working fine.
Thank You !
  • 69 Answers
SOURCE: Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Posted on Sep 25, 2007
  • 5 Answers
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
  • 5 Answers
SOURCE: Cuisinart Model TOB30BC Control Function
You can try to clean the contacts with alcohol (and/or very fine sand paper/brass brush...) as stated above, but the fix is a near term solution and eventually the contacts will arc and pit again. This leads to higher temperatures across the contacts and if the contacts fail before the plastic cam melts, your free to address the contacts for cleaning again. Just remember this failure will occur more frequently each time. Once the cam fails (melts) your out of luck. Write Cuisinart and tell them how unhappy you are with your toaster oven. If you get the same response I did (we only will replace it under warranty) then feel free to recycle it (or throw it away) and spend your money on a delonghi (no affiliation - my hand me down 7 yr old one keeps working great) or another brand. Companies these days should have better quality control on the products (from china) they slap their name on.
For the record, mine TOB030 has about 10 hrs run time on it before it failed @ 1.5yrs old. The inside is still brand spanking new!
Just my 2 cents.
Posted on May 30, 2008
Neuromancer1
SOURCE: No Oven but still Toasts
Never buy black & decker they don't supply parts they want you to rebuy the same junk over & over. its a shame this is what american companies have become buy japanese they last longer and make replacement parts.(I'm not unpatriotic just an informed consumer).
Posted on Aug 21, 2008
SOURCE: I need a manual for my toaster oven broiler
My B&D stainless appliance rusts? None of my Cuisinart's do.
Posted on Jan 04, 2009
Parts I need a new Broiler Rack (P/N 21432) for Toastmaster toaster oven, Model 337. Mine doesn't have the convection oven as it is an older model.
My manual has 1(800)947-3744 Mon-Fri 8:00 am to 5:30 pm CST I have purchased a broiler pan from calling them in the past; now my unit just died yesterday so need to find another.
Jul 01, 2014 | Toastmaster 337 Toaster Oven with...
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Looking for toastmaster under counter toaster oven
I'm selling a couple on e-Bay. Oldradionut seller.
May 04, 2010 | Toastmaster RA-5T Electric Oven
Toastmaster deluxe oven broiler
I bought a Toastmaster Deluxe Oven Broiler #5268 is it possible to get a instruction manual online?
Aug 08, 2008 | Toastmaster 328 Toaster Oven with...
Users guide for model 328
hi
this site might have one Toastmaster or even post you in the right direction
riz.
Apr 21, 2008 | Toastmaster 328 Toaster Oven with...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Kitchen Appliances - Others Logo
44 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
