Heating & Cooling Logo
A
Anonymous Posted on Jan 08, 2013
Need a wiring diagram for a vornado pvh vortex portable heater! Took it apart to clean it and can't get back together again.
5 Related Answers
Anonymous
  • Posted on Apr 25, 2008
SOURCE: putting back together the trimmer
I Need to kno a answer to this as well
A
Anonymous
  • Posted on Oct 31, 2008
SOURCE: Tripping BreakerS
I have the same problem with a new lg unit...it will trip the breaker after a few minutes of being on.
Anonymous
  • Posted on Nov 20, 2008
SOURCE: My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Commercial Appliance Service, Inc.
  • 81 Answers
  • Posted on May 12, 2009
SOURCE: need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
Anonymous
  • 3 Answers
  • Posted on Jun 20, 2009
SOURCE: took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Can't figure out how to take model EVH vortex heater apart to clean.
If you have access to a air compressor just blow it out, caned air is so so.You can put put the ca under hot water and get better pressure.
I have a Vornado Digital Vortex Heater. The fan stopped running in less than a year though the lights still come on.
Finding parts for a heater like this would be all most imposable you could how ever take it apart and put 115 volts to the 2 wires coming out of the fan to see if it is the fan or the switch that controls it. Check the switch with a continuity meter if the switch is bad you might be able to replace with a toggle switch the safest thing to do would be buy a new one these small heaters are mostly solid state which means you can't repair them .
Good luck.......
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
5answers
Power switch broken
I found this switch for a Vornado VH2 which seems similar, and you can order one at a time
https://www.digikey.com/en/products/detail/RR111C1000-116/EG4773-ND/2116252?itemSeq=386011899
Edit/Update: Jan 3, 2022
I ordered 2 replacement switches for $8.58 incl taxes+ shipping and today I received the replacement switch pictured below (on the left), together with the original (on the right), the only difference being that the replacement does not have the I / O markings.
Relatively easy to remove and install, and now my fan is working again.
6feb103a-41a1-41a7-b2ce-4d945eb91dbc.jpgpxl_20220103_175715311-dzvwud5c5tvrraz4xirosdrs-6-2.jpgpxl_20220103_175730845-dzvwud5c5tvrraz4xirosdrs-6-3.jpg
Fan shuts down, shortly after heater is turned on
I have a Lennox furnace that starts but won't ignite.
Turn up the thermostat, you can hear it start but the burners don't come on
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
3helpful
Thank you.
Top Heating & Cooling Experts
Paul Carew
john h
