Question about Maxtor Computers & Internet
Maxtor 6L080M0 SATA Hard Drive - Maxtor Computers & Internet
quarryswr
  • 43 Answers
SOURCE: broken plastic bit that connects the sata cable to the maxtor hard drive
Not really,if the retainer on the HDD is broken.
You could try embedding the sata cable to the HDD using a contact adhesive,but ensure none gets inside on contacts.This is only a qik fix but I have use in the past to get by.
Posted on Feb 04, 2008
mrsno
  • 166 Answers
SOURCE: Problems installing a SATA hard drive
Hi Tony. As you are using a SATA hard disk then I would firstly check a few settings, this involves loading the computer BIOS. When you see the computer first turn on, you should be prompted to press "F2" to enter the BIOS screen.
From here select "Enter BIOS SETUP UTILITY" then "Advanced screen" and finally "IDE Configuration"
Verify that 1) Onboard IDE Controller is set to "Enabled"
 and          2) “SATA Operation Mode” is set to "[non-RAID]"
Once you have done this, you should see the HDD listed beside SATA 1 or SATA 2 (depending on which port you plugged the hd in to) then press F10 to save and exit. The computer will now start up as normal.
If you have more trouble after checking these settings, please write us again.
Hope this helps
Posted on Apr 10, 2008
SOURCE: Maxtor 250 GB SATA problem: Foreign disk problem
Firstly, Unplug the cable connecting to the external HDD. Then go to my computer, right click on it and select use your legs and hands to dismantle maxtor HDD. Look at the maxtor brand title on the HDD. Press the 'X' letter as hard as you can for at least 100 times. The external HDD will open up to form the shape of letter 'X' and there will be a button called start to initialize the harddisk. After finish using, unplug the drive and HOLD IT TIGHTLY. IF NOT, IT WILL
FLY UP INTO THE AIR TO THE CEILING AND THE LIGHT WILL TURN RED WITH A EXTRA LOUD BEEP SOUND THAT MAXTOR DRIVES HAVE!!! GOOD LUCK!!!
Posted on Dec 14, 2008
  • 68 Answers
SOURCE: Hi, I have a maxtor SATA drive with my OS
The computer has to determine from which hard drive it will be booting
it cannot do so on its own
the user has to tell that to the computer through the bios
when your computer starts keep pressin F2 or delete key (acc to which you bios starts)
you will see a blue screen with lots of info on it
somewhere in there you will see a "boot " section, in there you will see hard drive priority
on that select your hard drive that has the OS as top hard drive
save and exit
there you go
Posted on Oct 04, 2009
  • 739 Answers
SOURCE: My hard drive is going bad. So says my HP Compaq dc7100 SFF
Instead of posting here, why don't you look for a dealer.
You can buy hard drives just about anywhere now - and it doesn't have to be Maxtor.
Posted on Oct 18, 2009
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
How do I set the jumpers on my Maxtor DiamondPlus 9 80 GB SATA /150 HHD drive as a second drive.
SATA drives are jumperless -- each drive has its own cable to the motherboard or controller -- so there's no setting on the drive to say "primary" or "secondary" as there was with IDE.
The connection on the controller or the motherboard will determine which drives are primary and which are secondary.
Jan 06, 2010 | Maxtor Hard Drive
Oct 18, 2009 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Need a scsi driver for maxtor 6L080M0
I am sorry to inform you that is not correct. If I am not mistaken this is your drive.
Maxtor DiamondMax 10 6L080M0 80GB Hard Drive Serial ATA-150, 7,200 RPM, 8MB - MPN: 6L080M0 Look at this link, it should help:
http://computeraccessories.suite101.com/article.cfm/sata_serial_ata_hard_drives
Jul 05, 2009 | Computers & Internet
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Shrinked
    This is the maxtor 4 installation utility: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=MaxBlast_4&vgnextoid=7add8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: MaxBlast 4 is a one-step, ATA/IDE hard drive installation utility. MaxBlast 4 makes hard drive installations and upgrades hassle-free for novices and professionals alike by automatically identifying, partitioning, and formatting any Maxtor ATA or SATA hard drive, making it data-ready in minutes. MaxBlast 4 replaces all previous versions of MaxBlast and MaxBlast Plus. Powermax 4.23: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=PowerMax_4.23&vgnextoid=a37d8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems. These problems include, but are not limited to the following: * Potential hard drive surface problems (e.g., bad clusters, bad sectors, partitioning/formatting problems, etc.). * Drive recognition problems (e.g. hard drive that is not recognized by the operating system). * Software removal.
    Mar 20, 2007 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
    Computers & Internet Logo
    41 people viewed this question
    Top Maxtor Computers & Internet Experts
    Computer Links
    terminalcon
    Jerry Umali
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
