Question about Sewing Machines
Noisy bobbin bounces in case
Machine sews fine but bobbin in case noisy. Bounces while sewing. I recently had a new case put in. I've cleaned everything, replaced bobbin making sure it is snapped in properly, sews without noise for a few minutes, then gets noisy again. I've tried about everything I can think of to fix myself since we live a distance from repair service & I've just had machine serviced a month ago. Help please!
  • 187 Answers
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Posted on Jul 23, 2017
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
  • 1388 Answers
SOURCE: bobbin thread bunching
I agree with brodering about the damage to your bobbin case, it should be smooth all over, as the thread travels across the top surface to form a stitch, and the small step on the underside locates it as the hook spins underneath.
Needle strikes often compromise the surface, as will the hook colliding with the under surface... and although it is possible to gently polish off the damage with fine grain wet & dry (black) sand paper (emery paper) there are limits to the success depending on the degree of damage.
While on the subject, ensure the bobbin case and hook race beneath are clean and free of lint or thread.
For a guide as to setting tensions and the rest, look here
Posted on Feb 24, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Posted on Aug 02, 2008
  • 15 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Posted on Mar 24, 2009
Noisy bobbin
If you bought new bobbins, they might not be quite round. This happens on mmetal bobbins.Another thing that happens is that you may have broken a needle and bent your bobbin case enough that the bobbin hits it as the shuttle goes around. If neither of these is the case, you might try to put a drdrop of oil in the "race" , which is the small grove in the piece that revolves around the bobbin case as you sew.
Mar 14, 2013 | Sewing Machines
My Huskvarna C20 is noisy when I sew, and I can see the bobbin jiggling like crazy. It worked fine yesterday!
Check your manual for trouble shooting. Also try to determine exactly where the noise is coming from. It may not be the bobbin area.
Jul 04, 2012 | Husqvarna Sewing Machines
Janome Gem 760 sewing machine: needle hits bobbin casing
from what I've read that you've put down it sounds like the machine is out of time, which means it needs to be fixed at a sewing machine repair shop
Feb 08, 2012 | Sewing Machines
Thread take up lever seems to have a metal clip showing that I didn't see before and the machine bounces the bobbin when it sews. HELP doesn't sew very well either.
The take up lever does have a little metal clip/spring that keeps the thread from getting out of it once it is threaded. It should just lay flat against the lever. If the bobbin is bouncing, it will be the wrong bobbin is being used or the bobbin case is damaged and vibrating. Take the thread off the machine and the bobbin out, if it sounds noisy with no bobbin then I suspect you need a new bobbin case.
May 28, 2010 | Janome Memorycraft 6500P Computerized...
I've been doing a lot of sewing over the past week and now the bobbin area sounds really noisy -like metal rubbing. The stitching is fine it sounds terrible. Do I need to oil the machine, and if so, where...
Hi. Your machine is probably just dirty. Have you cleaned out the lint? It will build up in the bobbin area and cause all kinds of problems unless you clean it out. A small brush works wonders. Take out the bobbin and bobbin case and clean all that old lint out. At the same time you clean the machine, you should also oil it. Use regular sewing machine oil and put one drop in all the oil ports (see my photo of an oil port at If you don't see the oil port, the old rule of thumb was one drop of oil wherever a metal part rubs against another metal part.
I clean and oil my machines after every 8 hours of sewing and I think that's pretty much what the manufacturers recommend, although some new machines are self-oiling. Check your manual to be sure. (Self-oiling machines still need the lint cleaned out regularly.)\
Hope this helps!
Apr 05, 2010 | Riccar Sewing Machines
Machine making a noise.
you may have put the bobbin in wrong so when runnng it pul on the thread which pops the bobbin,
check under the boobin case make sure it clear of dirt and thread, also the piece under the bobbin case may also have been push out of place make sur it is in correct.
Aug 26, 2009 | Singer Quantum 7350 Mechanical Sewing...
Sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
May 04, 2009 | Riccar R650
Noise from bobbin case on new Janome 4020
Check the bobbin to be sure it is inserted correctly. When you pull on the bobbin thread the bobbin should turn to the left(orcounterclockwise). If it doesn't, the thread will come out of the bobbin tension and give you loose stitches on top of the fabric. It will also make a noise because the bobbin is bouncing up and will need to readjust your tension again.
Dec 22, 2008 | Janome Memory Craft 9000 Computerized...
Kenmore Model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
Dec 11, 2007 | Kenmore 756A-30BH Mechanical Sewing...
Noisy bobbin
Is it the correct size bobbin?
If you have spare bobbins do they all make a noise?
Feb 17, 2007 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
