Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Set paper again/toner again error message canon mf-4340d
vipin_yadav1
  • 80 Answers
SOURCE: Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Posted on Dec 20, 2008
SOURCE: set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Posted on Dec 31, 2008
duane_wong
  • 6826 Answers
SOURCE: Canon image class MF 4150: it is flashing, message
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Posted on Jul 16, 2010
angelo_mlc
  • 1035 Answers
SOURCE: Error light flashing. Scren prompts set paper
The sensors are fooled into thinking that the toner cartridge is not present. The solution is to take all the paper out and reload the paper. I did this and found a single sheet of paper caught up in the paper feed path. I removed that page then turned the printer off and back on.
Try removing the cartridge and see if there are piece of paper inside or any material inside that would trigger the sensor.
Posted on Sep 30, 2010
  • 254 Answers
SOURCE: Showing an error set paper
hello
try follow the messages apper on the screen and power off the machine unplug he power cord from the outlet wall and also from the back of the machine. and wait 5 minutes and turn on again.
thanks
Posted on Mar 08, 2011
How does one open the printer enough to make certain no paper scraps are present?
Without removing the cover itself you really cannot be sure it is totally clear
Nov 28, 2015 | Canon ImageCLASS MF4350d Laser All-in-One ...
Error set paper again set toner again
after having opened the top and pulled it out. I recommend examining whether there is any evidence of loose toner in the machine at this point.Push the toner cartridge in to make sure it is properly seated.Then close the toner cover.Then close the scanner.
let me know whether this helps the problem any, or changes the machine's status.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon Office Equipment & Supplies
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Cannon MF 6580 with toner not set as error message
The toner cartridge goes in the left side door and there is packing tape that needs to be removed from the toner cartridge.
I hope this helps.
If not let me know
Thanks
Bob
Apr 16, 2009 | Canon Office Equipment & Supplies
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Toner not set
"Take out the paper from the machine and the toner cart unplug the power cord for 10 seconds then plug it back in that will fix it"
This solution worked for me but actually unplug the machine not just turn it off.
Jul 17, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
old marine
old marine
