Sharp mx-b200 error - Office Equipment & Supplies
3 Suggested Answers
upbeatjunk
  • 231 Answers
SOURCE: canon pixma MX 340 error
One of our FixYa experts has already addressed this issue. You can find the solution here:
http://www.fixya.com/support/t1257840-error_code_b200
I hope this helps! If this did help you, please give a thumbs up!
Posted on Jun 28, 2011
reyjoshua07
  • 1157 Answers
SOURCE: MX 850 b200 error. Started
Hi sakima,
This error code indicates a Voltage High Error of the Canon printer. The service manual write this, the internal temperature exceeded the specified value.
- Print head
- Carriage unit
- Logic board
Solutions:
1. Try using a different power outlet and see if that works and if that doesn't work try cleaning the print head:
2. Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
* Unplug the printer
* Manually slide the carriage over until you can get the ink cartridges out.
3. Remove the ink cartridges from the print head.
4. Use cotton swabs dipped in hot water or a mix of hot water and alcohol to thoroughly clean the print head.
5. Repeat this until there is no ink residue coming off on the cotton swab
6. Allow to dry and replace the cartridges
7. Try to print something
If it doesn't fix the error then you need to replace the print head, 90% the print head is the problem. If the problem persist then the board inside of the printer is faulty and you will have to replace it.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 31, 2011
How to program the machine sharp mx b200
Sharp Customer Support is better to approach a qualified professional so that an issue could be fixed in moments and you can get back to your work easily. They have solutions for all troubling conditions you come across while accessing your mail account and also contacts number 1800-204-4427 for all types' solutions.
Jul 20, 2017 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
Mx-b200 error code f2
Replace the drum/toner cartridge with OEM not third party
Aug 05, 2014 | Sharp MX-B201D Copier Machine
Sharp mx - b200 reset counter
With 24-6 and 24-8 with the same procedure 24-7 you can reset developer counter.
Mar 01, 2013 | Office Equipment & Supplies
347 people viewed this question
k24674
