Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Indy 500 motor knocks
Motor knocks
    Problem Solver:
  • 4 Answers
Could be bad gas. try running fresh gas. if that dont work you have internal problems. make sure it is firing on both cylinders though. when you start it cold you can feel if one is running hotter than the other. do a compression test. 120 psi is normal and no more than 10 lbs difference between cylinders. if one is low motor needs a rebuild
Posted on Feb 04, 2009
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
I tried starting my 89 Polaris Indy 500 it's
worn out engine, not creating enough suction. Does it run fine once warmed up? Mine does, but getting it started that first time is a real problem. I'm looking at a rebuild and I don't think it's worth it. Might be time to retire the ole girl.
Mar 03, 2013 | Garden
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
How do i change the date on my tag indy 500
Unscrew the crown like you are setting the time. Make sure the time shown on the watch is not around 12 o'clock. If it is change the time to around 6 o'clock.
Then pull the crown out to the first click. Turn the crown to advance the date. When finished push the crown back in and screw it down tight.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Need extra bracelet lings for a Tag Heuer Indy 500
Hi.  I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife.  I'm a smaller man and had to take out 3 links.  I'd never sell this watch so if you would like them...just write. croscow@comcast.net
Charles Roscow Silver Spring, MD
May 02, 2008 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
230 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
