Question about Microwave Ovens
Dead microwave oven
Stopped working. No power, lights or sound. Outlet and breakers okay, changed ceramic fuse. What else could it be?
  • 1,214 Answers
If you have a multimeter and are comfortable with testing "live" circuits, measure to see if there is voltage from chassis ground, to both ends of the fuse, or to each wire connection on the fuse holder.If no voltage, then the problem is very likely the wall plug does not have power (could be a wire broke inside the wall box.).
If there is power, chances are there is a controller board problem. You should have seen a wiring diagram/schematic when you disassembled to replace the fuse.
Posted on Jan 20, 2009
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Dec 01, 2015 | Daewoo KOR-1B4H Microwave Oven
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Hi! Our GE Spacemaker microwave (JVM241BL) stopped working..... nothing on it works at all. We have checked the breaker box in the basement and made sure it is plugged in. We are assuming it is a fuse...
Turn off the power before starting this process. If the oven is dead, the fuse is probably blown. Remove the two screws that hold the touch pad and control board in place to access the fuse. Once inside, look towards the back and follow the power cord that enters the rear of the microwave to the fuse. It should be a 15 amp ceramic fuse.
Dec 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I had a fire in the microwave and now it doesn't turn on. Is there a reset button or do I have to go buy a new one?
It sounds like an internal fuse has blown. Unplug unit and carefully open the top cover to provide access to the A.C. power cord entry point. Hopefully the fuse is located in that area and is the older style 1/2" long glass or ceramic body with metal endcap on each end. ONLY REPLACE WITH A FUSE THAT HAS IDENTICAL ELECTRICAL RATINGS! After replacing the fuse and top cover reconnect the unit to the A.C. outlet and check to see if it is still dead. Still dead = repair shop time.
NOTE: Use a "fused" A.C. outlet strip (usually 6 outlets with circuit breaker) for your "after fuse replaced" testing. This gives you additional protection against accidentally tripping a breaker in your homes electrical panel.
Oct 19, 2010 | Maytag Microwave Ovens
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
Microwave power just stopped
if the lights and turn table still work, then its either your h.v. diode,h.v. capacitor or the magnetron tube at fault, if nothing operates then its the internal ceramic fuse under tho outer unit cover thats bad or your outlet is dead at the wall
Oct 16, 2009 | Viking VMOS200 Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave Ovens Logo
174 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
