Question about Dell Precision Workstation 670 PC Desktop
How can i install VMWARE on dell 670
I am unable to find virtualization option in 670 machine.. Now kindly list down the steps that i should do to install VMWARE in my machine.
4 Suggested Answers
knightsky
  • 4 Answers
SOURCE: Dell Workstation 670 video
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
All the info for your pc can be found here..... http://www.dell.com/downloads/global/products/precn/en/spec_precn_670_en.pdf
Posted on Jan 15, 2008
sandrew
  • 2961 Answers
SOURCE: Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Posted on Sep 01, 2008
  • 32 Answers
SOURCE: My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Posted on Feb 04, 2010
How to Install Ubuntu 11.04 on VirtualBox?
http://www.osboxes.org/ubuntu/
http://www.wikihow.com/Install-VMware-and-Use-VMware-to-Install-Ubuntu
Oct 19, 2016 | Computers & Internet
How do I add windows 7 to a dell xps 8700 that came with windows 8.1 using a separate hard drive? Is it possible?
No, it isn't possible doing it the way you want to. You can't have 2 operating systems running at the same time. When you start win 8.1, that OS is running, and installing Win 7 on an external SSD won't work while Win 8.1 is running. You can install VirtualBox for free and create a virtual machine to run Win 7 inside of Win 8. You can do the same with the free VMWare Player. You can also shell out some money for VMWare Workstation and create virtual machines that way. Another option is to create a dual boot machine on your Win 8.1 machine. That is out of the scope of this message right now. There are lots of tutorials on the web.
Sep 16, 2014 | Computers & Internet
Pxe mof exiting intel pxe rom
You are going where no man has gone before. Go to the VMware forum and see if they can help. I gave up on this VMware 2 years ago. Just can't get it to work. And I'm a technician!
Mar 15, 2014 | Toshiba Computers & Internet
How do I run a virtual machine on asus M51AC?
Install a virtual machine application and create a virtual machine
Virtual Machine Applications
  • VMware Player or VMware Workstation
  • VirtualBox
  • QEMU (linux)
  • Virtual PC
Jan 23, 2014 | Computers & Internet
Need help installing MAC Os x 10.63 as a virtual machine on oracle virtual box on win7 host
Upon starting VMware, click on the New Virtual Machine button.A Wizard will open. Click Next.Select Typical. Click Next. (On later versions of VMWare, select Custom instead so that you can set your disk drive to IDEinstead of SCSI, as required below.)Select Other, then pick FreeBSD. Click Next.
  • IMPORTANT NOTE! If you are using a Conroe or Core 2 Duo, select Windows and then Windows NT from the dropdown list. Using FreeBSD will cause a stack fault on boot. Same applies to Core Duo (945PM/Calistoga).
You will likely need to select one [1] Virtual Processor as well. Selecting 2 Virtual Processors will likely cause installation and/or bootup to fail.
  • for Gigabyte GA-965P-DQ6: IDE is used instead of SCSI. otherwise the system will not be able to find any installable disk.
  • for Asrock Conroe 945G-DVi: IDE is used instead of SCSI. otherwise the system will not be able to find any installable disk.
  • Dell E1405 and D620 (and maybe other Dell Core Duo laptops): IDE is required instead of SCSI.
  • for Asus P5B-VM IDE is required instead of SCSI, otherwise the system will not be able to find any installable disk.
  • (If you do not see this option, go back to the beginning and choose Custom instead of Typical. You cannot change SCSI to IDE once you have created the VM.)
Name it whatever you want (I used Mac OS X), put it wherever you want. Click Next.
  • Location of virtual harddisk drives can be determined at this point in time. For best performance always try to put virtual machines on a separate physical hard drive. Partitions don't count. This is because the biggest performance hit in virtual machines is disk I/O. If the VM is on the same drive as your OS the VM fights with your OS for disk access. When the OS needs to use a swap file it makes the matter much, much worse. Additionally, today's USB 2.0 and firewire external hard drives run on a fast interface bus, have large buffers and spin at 7,200 rpm, as opposed to 4,200 rpm for most laptop hard drives.
If you are using a non-legal copy you'll want to use Host-only networking initially to prevent Mac OS X from registering itself during installation. If this is a legal copy, use NAT. Click Next.Set the Disk size to anything greater than 6GB. You don't have to but I recommend that you allocate the disk space now so that disk performance is increased. When done, click Next. You may also split files into 2GB pieces if on FAT partition.Click Finish. . . .[edit]Step 4 - ?????[edit]Step 5 - Profit![edit]Step 6 - Setting up your Virtual MachineOpen up your new virtual machine configuration.Under Devices:Double click Memory and set the amount of RAM you'd like to use. The minimum is 128MB but the recommended minimum is 256MB. Make sure you don't use too much of your total RAM as swapping may occur and could lead to big problems! I use 512MB (out of 1GB System) and I have set my Memory Preferences [Edit>Preferences>Memory] to Fit all virtual machine memory into reserved host RAM.Double click the CD-ROM drive and select the letter of the Virtual Drive with the mounted ISO that you created with Alcohol 120%. If you are using Daemon Tools you may not see your drive listed. See the next step for further details.Now EXIT VMware. Here comes the boring part =P[edit]Step 7 - Editing your VMware ConfigLocate where you've stored your Virtual Machine files in Windows Explorer.Mine is ..\My Documents\My Virtual Machines\MacOSX\Open up your Virtual Machine Configuration File (.vmx extension) in Notepad.Add the following line to the end of the file.paevm=true
(note: If your CPU does not support PAE, you can't run OSx86 under VMWare on your CPU; OSx86 needs a PAE compatible CPU to work. Intel Pentium M <1.5GHz do not have PAE, so don't try it on those CPUs)
If you are using Daemon tools you may need to help VMware find the drive. If that is the case then modify the lines in the configuration file referring to the CD-ROM drive similar to this (note replace X: with the drive you have configured in Daemon Tools):ide1:0.present = TRUEide1:0.fileName = X:ide1:0.deviceType = cdrom-rawSave the Config file, close Notepad, and continue to Step 7.
Note: on 10.4.8 8.8.1 kernel and networking: This is a good time to remove existing ethernet0virtualDev (if any) and add:
ethernet0.virtualDev=e1000
Note: sometimes scsi0.present = TRUE won't work, so set it to False:
scsi0.present = FALSE
Note: if you change any settings in the VMware interface after editing the .vmx file, it will overwrite your changes. You will need to go back and change the settings again! It is best to make these edits while VMware is not running.
Here comes the fun part =D[edit]Step 8 - Installing Mac OS XStart your Mac OS X Virtual Machine.When the Mac OS X boot prompt appears, click the logo then hit F8 to add boot options.Type in -v and hit enter. This puts you into Verbose mode which will let you know if something is going wrong.It may take a while depending on your hardware to load the installation. Be patient.
How to correctly uninstall Mac programs
how to restore mac
[edit]Step 9 - Setting up your Hard DriveFollowing along in the installation, you'll reach a point where it's time to select your Hard Drive, but nothing is listed.Open Utilities -> Disk Utility on your disk
Note Re 10.4.8: Disk Utility has been reported not to work (it makes an efi partition). Use a prior version to partition your disk, or partition it with another OS, then use 10.4.8 disk utility to erase (by reformatting) this partition. Otherwise it won't boot. Note: no need for using a previous version just apply PPF2 to fix the disk utility http://forum.insanelymac.com/index.php?showtopic=38125
Select the VMware drive on the left. Click partition on the right.Change the Volume Scheme to 1 partition and choose a name. The format should stay Mac OS Extended (Journaled) and the partition should use all space available.Click partition, then partition again. After it is finished (progress in bottom right), you can close the Disk Utility.Your drive now shows up in setup. Proceed, proceed.[edit]Step 10 - Using a Custom InstallationIf you have a patched installation you should select a custom installation to see if there are patches listed there that you'll need to include (such as selecting the appropriate patch set for your CPU, see Comment 2). Another place to check is opening up a Terminal window and looking around the installation disc..
Jan 28, 2012 | Apple Mac OS X Server 10.6.3
Is there any driver, program or software fix that will allow me to load my "Intel Create & Share Software on my Windows 7 Dell Inspiron 530?
The Intel Create & Share was written for Windows 2K and XP and not updated. The workaround is to use a computer (second machine, dual boot or virtual) with XP installed.
If you have Windows 7 Pro or Ultimate or update to one of those versions, you may be able to run a virtual XP computer for free. Download from Microsoft and install in order the Virtual PC program and the XP mode software. Install the Intel Create & Share program in XP mode as if it is your only OS. (Note: you can't have hardware installed on the virtual and real computer at the same time. To share files you will need to save them to external media (USB or optical disc).)
Other virtual computer programs are VMWare and Parallels. For the other options, you will need a licensed version of the older Windows OS.
I hope this helps.
Oct 09, 2011 | Dell Computers & Internet
My macbook shows a white screen and a sound only and after that nothing happens
JUST TRY TO FOLLOW THE STEPS IT WILL BE VERY HELPFUL
Many computer shoppers choose to buy a Mac not only to use OS X, but Windows as well. That is one strong advantage that Macs have in the Mac vs PC war. Apple computers are capable of running Windows, either through Bootcamp or virtual machines.
So, why aren't Windows PC's capable of running OS X? Well, Windows PC's are capable of running OS X. But, it is against Apple's licensing agreement to do so. Thus, this article is intended for educational and demonstration purposes only. If you want to run OS X the best way possible, get a Mac.
*In order for this to work, your computer must have a processor that supports virtualization. If it does not, you may receive errors. For the most part, any newer processor lines: Core 2 Duo, Quad Core, and Core i7 should all work fine.
But, don't expect to not get errors if you are using an older Pentium 4 machine. The processor must be Intel and not AMD*
Because we will be installing OS X on top of Windows through a virtual machine, the first step is to get some virtual machine software. For this demo, we will be using VMware's Workstation 7.
If you do not feel like purchasing Workstation 7 at this time, you can get a limited trial here. The download may take a good half an hour to complete. Workstation is a 512MB file.
Upon download, go ahead and install Workstation 7 onto your computer. The installation process is very simple just launch the installer, and the VMware installer will guide you through the rest.
One thing to note, when it asks your if you want to do a custom install or a typical install, choose typical install. After the installer finishes, restart your computer
Now that you have Workstation 7 installed, you need a pre-configured VMware virtual machine file to install Snow Leopard on top of. Download this file (alt download) and save it to your desktop.
After you have the pre-configured virtual machine file downloaded, you will need to extract the files using WinRAR or another archive utility. If you do not have an archive utility, you can get WinRAR here.
Note: This file is just a disk image framework, no viruses or anything like that. VMware Workstation uses the disk image format to save and contain virtual machines.
Time to start installing Snow Leopard. Launch VMware Workstation by using the path Start > All Programs > VMware > VMware Workstation. Open up the VMware disk image framework that you just downloaded and extracted.
Select File > Open. Navigate to your Snowy_VM folder, open it, open up the next folder that says "Mac OS X 10.6 Server (experimental).vmwarevm, and choose the 2KB file that is named Mac OS X Server 10.6 (experimental). Click the open button to load the virtual machine.
From the Mac OS X Server tab in the VMware Workstation window, click the edit virtual machine settings icon. You may adjust the hard drive size, memory, etc, to your liking.
Select CD/DVD (IDE) and under the Connection settings, select Use ISO Image File. Click the Browse button and navigate to the Darwin_Snow.iso which is located in your Snowy_VM folder. Click the Open button to select the virtual machine.
Now it's time to power on the virtual machine. Click the Power on this virtual machine option. As soon as the process starts, hold down the F8 key on your keyboard. You should be prompted with a boot menu screen.
If you have not done so already, insert your OS X Snow Leopard Install DVD into your computer's CD/DVD drive. So far, you have loaded a workable virtual machine and framework into VMware Workstation.
Now it's time to actually install Snow Leopard onto that virtual machine disk image. You should see some settings icons located at the bottom right portion of the VMware window. Right-click the icon that looks like a CD and choose settings from the pop up menu.
Go back into the boot screen and select the option C Boot from DVD. Press the F8 button on your keyboard for advanced options and type "-v" without the quotes and hit enter. Now, VMware Workstation should boot your Snow Leopard install disc. It may take a couple of minutes to load
That's all there is to it. You should now be at the normal Snow Leopard install screen. Click continue on the first screen that comes up. On the second screen, click the utilities option in the install window and select disk utility. Use disk utility to change the hard drive format type to OS X Extended (Journaled). Exit disk utility and let OS X install completely.
Upon install of Snow Leopard, your virtual machine will restart. After it restarts you will need to do a couple of things to get into Snow Leopard. Select CD/DVD options, like you did before, and use the Use ISO Image File option.
Sep 26, 2010 | Apple MacBook Mac Notebook
Version 4 of bernina artista will not load on my new computer
I have a solution. (sorry for my bad english) Last week is the notebook of my wife broke down (mainboard was ten years old). So we bought a new one. So I tried install artista V4, no chance (bernina said, you can update to V5). Next step, I install a XP-Pro on the new notebook (no chance too, because I can't find all drivers, they don't develop new drivers for XP).
Now my solution:
I installed a virtual machine (vmware player) with XP-Professional (which I have). At this XP-Machine I installed the artista V4 - it runs!
You can find a lot of help for installing a virtual machine in the www.
If you want, I'll describe the install-process for my vmware.
I hope I could help!
Regards
David
Aug 22, 2009 | Bernina Artista 180
VMware Tools Installation Problem
Use Ultra ISO or other VCD-ROM to mount the cd iso image on your hdd and map it in VMware F
Jan 04, 2009 | VMware Fusion Full Version for Mac
On vista i have vmware 6
Your Guest OS uses a Virtual VGA adaptor. As with a normal computer it needs drivers. This usually is installed through VMware Tools. (VMware tells your guest OS there are all kinds of virtual devices. They don't exist physically but need their drivers since VMware uses the virtual devices to handle the Host PCs physical devices.
In order to install VMware Tools, go to:
VM > Install VMWare Tools.
Remember that you need Administrator rights.
Need more help? See the link below:
[Installing VMware Tools]
This should do the trick, let me know if this solved your problem.
Greetings,
DarkNeogen
Jan 23, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Precision Workstation 670 PC Desktop Logo
80 people viewed this question
Alun Cox
