recently pick up Dell Inspiron 8100 with the problem during startup will not boot to software but goes directly to C prompt. Tired putting in the CD Win98 still would not boot to. Used the CD Spotmau to boot up and recover. Spotmau would boot but states all files missing can't recover. Would a bad hard drive cause this type of problem?
Comments:
Feb 25, 2009
- That problelm has been resolved and repaired. thank you! But most recentl problem has not.
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Comments:
Feb 26, 2009
- Have you checked to make sure that all of the pins on the hard drive are intact and not bent or broken, I had a similar problem with a desktop and found a bent pin that was ocasionally making contact. If that isnt the problem then there may be a problem with the read head or the recording medium its self. You can get a 40 gig laptop for about 40$(which is a bunch in this economy) as a last resort, i would just makesure that the cmos battery is good and bios boot section are correct and if that doesn't work you may want to try a replacement of the hard drive if a format and reinstallation of the os dont fix the problem. Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Dell for Inspiron 8100 40 GB
WD3200AAJS Caviar SE. Started with not recognizd by WindowsVista. Restarted computer, worked for a...
(More)
WD3200AAJS Caviar SE. Started with not recognizd by WindowsVista. Restarted computer, worked for a while, now when pluged into AC, bluelight on front just pulses. what now? how to make internal? Thanks...Jason
I have a Buffalo 320GB Ministation hard drive. It works fine except when I want to save a file...
(More)
I have a Buffalo 320GB Ministation hard drive. It works fine except when I want to save a file larger than about 4 GB. It then gives me an error that there is not enough room on the disk even though the disk has 150+ GB free space. I suspect this is a format issue. How do I fix this?
mini pal seems to be dead. Power lights up on the face . drive doesn't seem to run up. Had been...
(More)
mini pal seems to be dead. Power lights up on the face . drive doesn't seem to run up. Had been alternately running fast and slowing. Anything I can do mechanically to fix the drive? make it spin the disk again?
Would like to upgrade my memory but I do not have a model number; system was built at gateway. I...
(More)
Would like to upgrade my memory but I do not have a model number; system was built at gateway. I know I have 512 MB of Ram and can upgrade but need to know what to purchase.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
