Question about Whirlpool Calypso GVW9959K Top Load Washer
FL Code on whirlpool calypso
What to do?
    Scholar:
  • 48 Answers
Flood Condition - overfill; excess water in the tub. With this condition the beeper repeats a warning every 10 seconds with no timeout. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is disconnected from the unit.
May be a sign of a pump motor problem - clog, jam or failure. There is a redesigned single piece pump/impeller assembly that you should upgrade to if the unit doesn't already have that kind, if it turns out the pump has failed.
You may be able to clear the fault by removing debris from the pump water tubes or impeller. I've had to disassemble from the bottom of an unplugged unit to get a draw string out of the impeller, or a sock out of the ball valve which reverses the flow of water when the pump changes direction.
Takes a little practice, but it can save big on repair bills if you are comfortable poking around underneath a drained washer. Problem is, when you have a FL condition, you may have to bail out the water or use a wet/dry vac to **** it out of the drain tube, to avoid a mess in the wash room.
Posted on Jun 13, 2009
  • 99 Answers
SOURCE: whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Posted on Feb 06, 2009
tatunka
  • 85 Answers
SOURCE: FL alert
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Posted on Sep 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Posted on Nov 08, 2009
  • 530 Answers
SOURCE: whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
Posted on May 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Flood Condition:
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer stuck on FL
Fl means flood
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Thanks, Ella :>)
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso wash motion washing machine FL code stuck
Calypso washers have been known to be problematic. In fact, there is a class action suit out there which could be beneficial to you: http://www.calypsosettlement.com/ According to Whirlpool FL stands for Flood Condition. Here is their explanation of it: ----- FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. ----- Hope this helps.
Aug 07, 2006 | Whirlpool Calypso GVM9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
