Question about Samsung AK59-00104R Remote Control
My AK59-00104R remote control stopped working; the TV Power bottom as well as volume control are not working
SOURCE: HLP5063W remote control
i did solve the problem,,,my "mode" button was not on TV... thanks
Posted on May 07, 2008
freetek
  • 5568 Answers
SOURCE: tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete. The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
Posted on Sep 22, 2008
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
  • 325 Answers
SOURCE: none of my remote controls will control the volume on my samsung
buy yourself a cheap sky remote or get one off a friend or family member.
on the sky remote:
TV,
RED + SELECT (blinks twice)
TV,
0060
TV,
SELECT.
there you go you can now use this as a telly remote and change your channel over, volume, power, if you press the help button this will also change your source/av's
Cheers
Little Dish Fitter
Posted on Sep 02, 2009
PhilwithDISH
  • 123 Answers
SOURCE: I have a samsung lcd
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Posted on Mar 02, 2011
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
The + volume button is not reponding
if all the buttons are working and only this one isn't working then there's something wrong with how it functions. does the button have a double function?
Jun 11, 2010 | Samsung TV Remote Control
None of my remote controls will control the volume on my samsung
on the sky remote:
TV,
TV,
0060
TV,
SELECT.
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung Remote Control
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Samsung AK59-00104R Remote Control Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
