Question about Arris Touchstone 450a (CM450) Modem
No driver for my modem
I have a arris cm450a and i cant find a driver can someone help it is not usb
  • 31 Answers
There are no drivers for the arris cable modem unless you are using USB.
If you are using ethernet then it is simply plug and play. You may need to press the reset button on your arris.
Thank you.
Posted on Apr 09, 2009
I have a modem arris cm450b, i bought splitter to use 2 cables but the the cable connected to my sons computr isn't working
That is not the right way to do it. Connect one computer to the cable modem using an USB A/B cable from the USB port on the modem to an available USB port on the computer and connect the second computer to the modem Ethernet port-to-Ethernet port using an Ethernet cable (probably the modem came with one Ethernet cable).
Hope this helps.
Oct 14, 2014 | Arris Touchstone 450a (CM450) Modem
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
I am looking for usb driver for arris rndis modem model number is tm602g
http://www.drivers-fix.net/arris.php. Comcast sometimes has drivers for this device. Use the ethernet connection if you can cause Arris EMTA's usb outputs **** unless your trying to do both which is what I think your doing. If your computer only has a USB connection look for adaptors
Oct 11, 2009 | Arris Touchstone 450a (CM450) Modem
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Usb drivers for arris tm402
Hello:
Please check the following link:
http://www.softwaredriverdownload.com/download_arris_touchstone_telephony_modem_tm402_usb_drivers.html
Regards,
Jagg
Apr 21, 2008 | Computers & Internet
Usb drivers for arris rndis adapter
Follow this link and choose your operating sysem and model. You can download from there. If this is what you were looking for PLEASE rate this solution a 4 for fixed ya. Just click on the fourth diamond. Thanks. http://www.arrisi.com/support/usb/index.asp
Mar 29, 2008 | Arris Touchstone 450a (CM450) Modem
HELP
need to find the wep key
Mar 25, 2008 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone 450a (CM450) Modem Logo
448 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
