Question about HP LaserJet 3600n Printer
When printing in color the colors are off set
Black toner works fine for printing but when I try to print color copies the three colors do not print on top of each other rather they offset each other and it looks almost like 3-D
  • 2 more comments
  • kevinroberts Jan 20, 2009
    I tried to shake the color cartridges and that did not work.
    I am having a problem with color copies when the print comes out the colors are off-set and the image looks 3-D
    The printer goes into recalibrate mode itself. it has done this a few times and still no success.
    Where are the optics to be cleaned? Where are they located and what do they look like?
    They are still off set by taking the color toners out and shaking them
  • HP Master
  • 19,396 Answers
Defective toner cartriges, or refilled or refurbished toner can cause HP printer not calibrating , if you are using non original toners, that may be the cause.
If toners are originals (yeah I know they are expensive) then see if you have a set of cartridges to test the printer, even half empty will do.
There is also a firmware issue related to calibration problem, if you have old firmware, that can cause the calibration procedure failing on determined circumstances.
Ensure you have the latest firmware, call HP to verify, read the thread below:
Business support forums - HP Color LaserJet 3600n
If the printer does not calibrate, you did calibration procedure properly, and toner is new and original one, then there is a fault.
Usually when printer does not calibrate, that is because one or more density sensors, environmental sensor or the board are faulty.
Call HP to get step by step instructions on how to locate and remove parts without damaging the printer:
Customer Service / Contact HP
Posted on Jan 21, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Sounds like toner cartridges are shorting against each other or with the roller, may be due to dirty roller or toner powder spill. It happens when the toner powder is peviously charged and will not stick with the other toner powder, and so would appear as a spectrum thing.
  • Rylee Smith
    Rylee Smith Jan 21, 2009
    You can try and callibrate your printer after cleaning---
    To run Full Calibrate Now on HP Color LaserJet3600n-
    a. Press MENU or Select button to enter the Menus.
    b. Press t (Down arrow) to highlight CONFIGURE DEVICE, then press select.
    c. Press t(down arrow) to PRINT QUALITY, then press select button.
    d. Press t(down arrow) repeatedly to CALIBRATE NOW (FULL CALIBRATE NOW on some models), then press select button.
    Sergeant:
    Scholar:
  • 199 Answers
Your colour toner cartridges needs to be removed and cleaned with a dry  cloth.as this happens if the toner power is leaked from the toner.or also if the toner is near to empty.it leaks because the waste toner collector gets full and then it leaks while printing.to resolve just get it refilled or replaced,it will solve the problem.
Posted on Jan 20, 2009
    Sergeant:
    Novelist:
  • 326 Answers
The assembly is misaligned creating the laser optics to print in a shaded mode on each other.clean the optics and check or else get it replaced.
  • 8,197 Answers
You need to recalibrate the printer. It is in the printer setup menu properties.
    Sergeant:
  • 378 Answers
Remove all the colour cartridges and shake it well for couple of minutes and reinsert.
Lexmark pro 900 will not print color
Try to check your printing preferences if it's set to print using all available ink or check if it's set to print in black and white. To do that, on the application that you're printing from, click on File > Print > Preferences/Properties.
Also, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Jan 30, 2013 | Lexmark Office Equipment & Supplies
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Dell 1320c is giving faded printing in both color and black. I've replaced two toner cartridges, tried to 'bleed' the cartirdge by printing 20 copies, toner save is turned off and there is no...
After you click print, and just before you print, go to your 'printing preferences' or 'print settings' in the popup window. From there, cycle through the tabs, and ensure that 'print quality' is NOT at draft and IS on normal or high quality. Alternatively, you change the 'print resolution' in this window, if the option is available. Resolution is usually given in 'dpi' so choose the highest 'dpi' value. This should hopefully give you darker prints
Aug 26, 2011 | Dell 1320c Laser Printer
Light print on side of paper. color black copies, print, internal
Ninty-five percent of all image issues like this are caused by the carona-drum-toner assembly. I have not worked on this model but the only way to diagnose the issue is to try a new drum / toner cartridge and see what impact it has. Then once you resolve the issue you can discuss the service life after the fact.
May 12, 2010 | Brother MFC-9440CN Laser Printer
How do I set my 5550n printer to print only black and white copies and color on demand?
If you go into control panel then go printer options you should see your printer icon. Right click on it and go printer preferences or printer properties and I think there is a colour tab where you can set it to just back and white
Sep 22, 2009 | HP LaserJet 5550n Printer
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Have you tried to reinstall the printer driver?
Jun 29, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP LaserJet 3600n Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
