Question about GE Profile DPSR473EW Dryer
GE Profile dryer Model # DPSQ495ET0WW squeaking
I was wondering if you knew the model # for the bearing kit I need to buy to stop the squeaking.
  • chrstnen Jan 20, 2009
    The squeaking is actually coming from the front. Is it still a bearing kit I need to replace it or is it another part? Thanks for your help!
  • 61 Answers
Yes the part # is WE25M40
Posted on Jan 20, 2009
  • Shawn Smith Jan 21, 2009
    WE03M20 and two WE01M316 and two WE01M333 are the parts for the front you will need
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
GE washer squeaking
Make sure the felt on the rim of the drum is secure and the plastic glides that the drum sits on are not worn down.
Jul 27, 2010 | GE Dryers
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile dpsq495et0ww has a severe squeak to it. we checked out if it was the belt. and the belt looks good. when we take off the front door it doesn't squeak when we turn it on but if i manually turn it...
The problem could probably be with the drum bearings or the drum support rollers. The following link direct you to the internal diagrams of this dryer model with the part selection in case of any damaged parts. Hope that helps you out.
Dryer internal diagrams
Also will look out for manual and will post in few hours. Please do rate my solution if accepted and also post comments regarding any doubts with the solution provided.Good luck with the machine.
Apr 08, 2009 | GE Profile DPSR473EW Dryer
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
Sep 17, 2008 | GE Profile DPSR473EW Dryer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Dryers Logo
303 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
