Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Bonaire vsm65 discharge from overflow after shut down water draining from celdek pads has been draining for 2 days is this normal
It seems a long time for water to drain from pads or should dump valve activate or could it be that float valve is not set to the right level
5 Suggested Answers
  • 40 Answers
SOURCE: when ballcock stops the water
the 6mm hose is a bleed off hose and is meant to leak water out. the tap is to adjust the quantity. if you dont want any leaking out remove the hose from the dump valve and have it drop back into the tank
Posted on Apr 04, 2011
  • 40 Answers
SOURCE: Bonaire VSM65 won't start, have had a recent
check the fuse in the unit
EMSRSERVICEG
  • 426 Answers
SOURCE: The float valve will remain
have you called the maker they will tell you what you can do
Posted on May 18, 2011
  • 64 Answers
SOURCE: master cool ll unit recycles
In most cases you will need to just adjust the float (grab the metal shaft and bend it downward) this will lower the water level. If this doesnt do it, then you probably need to replace the entire float assembly. This is normally a n easy and cheap thing to do.
Posted on Jun 10, 2011
Odor coming from a new bonaire evaportive cooler----have run for 5 days but odor [musty] persists
New evaporatives will smell for a fair amount of time. Its the preservative and glues which are used in the manufacture of the filter pads. Using the machine on cooling for 5 or 6 hours should normally clear this. If not, you can mask the smell by pouring a small amount of disinfectant into the machine whilst on its cooling cycle. (You will have to get on the roof for this if its a roof mount) The machine should dump out the water and refill with fresh water in 2 ways. Manual bleed off will have the machine dribbling water out the drain pipe all the time the machine is working or an auto drain will let all the water out immediately you switch off or after a preset time depending on what type of auto drain has been fitted.
Mar 20, 2017 | Washing Machines
How to change the filter for vulcan evaporative cooler
I suppose you meant Vulcan Bonaire evaporative cooler.
By filter, I suppose you meant Filter Pads. Here is extract from the Owner's Manual.
Filter Pads: Visually check CELDEK pads for damage or blockage. Hose down pads from both sides to remove any build up of salts, dust and pollen. In dusty areas more regular
cleaning is recommended. Check the water distributor, making sure it is clear and free from blockage. Failure to do so may lead to uneven water distribution and therefore less efficient operation. Do not hose Celdek with high pressure.
Dec 21, 2013 | YouTube Videos
I have the pentair 011523 whisperflo and our spool is going to overflow from all the rain we have been having. I know that there is a way to attach a hose flip a switch and drain some of the water to...
To drain the pool, you have to change the position of your "backwash" valve.
Shut off the pump.
See if there is a DRAIN position on the backwash valve.
You could probably use the BACKWASH position, too, only water will go through the filter and then out the normal backwash pipe.
Turn the pump on briefly to see which pipe water comes out. Shut the pump.
Put discharge hose on that pipe.
Turn pump on until pool is low enough.
Return backwash valve to filter position.
Gary
Dec 19, 2010 | Pentair Pool & Spa
How do I drain coolant from a 2001 ford mustang GT?
unscrew the freezeplug located on the bottom corner of the radiator
Aug 17, 2010 | 2001 Ford Mustang
Whirlpool Gold dishwasher water overflowing and will not shut off
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Jun 28, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Erestanding Equator PLS600 Overflows
May be this time the drain hose has been clogged or the drain hose is at a higher level than the unit or may be the drain pump has stopped functioning.
Mar 09, 2009 | Equator 20 in. PLS600 Free-Standing...
Wet cloths need help please!!!!!!!
F9=Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Check the drain hose and make sure it is not plugged or inked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check for Drain Pump Failure
Check the Inlet Valve for proper shut off
Check the Pressure switch for proper operation
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Candy Futura Fridge Freezer
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Aug 28, 2008 | Candy CPCA240FFK Bottom Freezer...
Water overflowing of defrost water pan
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 02, 2008 | Refrigerators
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
83 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
