Question about Sony STR-DE875 Receiver
Sony s-master digital amp turns on starts,push power protector?
Runs  thro start up  disk  changer  sounds  like it  wants to  open  but  stuck , can  i  reset myself???
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: protector push power - dvd home theater system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
I have a Sony S-master digital amplifier. When I power it up a (push power protector) image on screen. It is holding me from doing anything else. How do I get rid or fix it
that usually means there is a problem in the amplifier. Most likely a shorted amp IC. This will need to be replaced before the unit will power up correctly.
Apr 07, 2015 | Sony Audio Players & Recorders
So i have a 96 cadillac eldorado with a ten disk sony changer mounted in the trunk and it keeps saying E-99 i already unjammed the disk becuase it was stuck on it but i cannot find the reset button on it n...
it should be on the bottom edge when you open the cover to access the Cd's and if you still cant find it just unplug the changer unit for about 5mins then plug back in. generally a rest interrupts the main power connection when it is pushed
Jun 08, 2010 | Sony CDX-454RF 10-Disc CD Changer
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Cd stuck in cd changer
You could take the radio out and take it apart, but you would still have an $1800 CD. Suggest forgetting about the CD, and getting an aftermarket installed for much less.
Mar 07, 2009 | 2005 Suzuki Aerio SX
Protector push power - dvd home theater system
Bad speaker wiring.
Internal fault.
Regards.
Jan 20, 2009 | Sony STR-DE875 Receiver
Protector and "push Power"
Please check speaker wires should be properly connected and not touched / shorted.
Push Power Protect is error sign when unit got problem in Power Amp area and mostly its Power Amp Out IC failure.
I would suggest to ask Sony for warranty cover.
Nov 30, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony STR-DE875 Receiver Logo
993 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
