Question about Zanussi FS1455W Front Load Washer
What size torx head do I need
To remove torx bolt on zanussi zwf1421s washing machine - specifically, the 5 bolts holding the concrete balance at the front and the single bold retaining the drum inside its shell
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
breddi2
  • 126 Answers
SOURCE: Concrete counterbalance broken (Frigidaire FWT449GFS1)
Check with a company online called sundberg appliance parts, the counterbalance isn't hard to install and will definately be cheaper than new one.
Posted on Apr 23, 2009
SOURCE: Zanussi ZWF14070 - concrete 'damper'
Moulded plastic 'spigots' still form part of the drum housing, but no concrete block is now fitted to the rear.
Posted on Nov 17, 2009
What is the name of the parts that hold the stone in whirlpool washing machine
I assume you mean the concrete balance blocks? They are normally held in place with a few bolts with large washers or a plate to hold them in place.
Mar 20, 2017 | Whirlpool Washing Machines
What is the Torx socket size for spark plug cover?
you dont unscrew the cover,you pull the plug wire to access the plug and then use an extension with your socket
Jul 11, 2015 | 2000 Cadillac Catera
Apr 23, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Washer LTF530DS1 walking
remove bottom and ck for 2 braces that may have been reinstalled they bolt from base to lower balance block remove them also ck the shocks to make sure they didn't get broke
Sep 02, 2008 | Whirlpool WFW8300SW
Problem washer will not wash or spin
If the drum does not turn by itself then there are two things which could be wrong.
1. the belt which drives the drum is broken or come off.
2. the motors brushes which wear down now need replacing.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...about half an hour...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wma40&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
To do the brushes - about half an hour...
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
Jul 08, 2008 | Hotpoint WMA40 Front Load Washer
Need to change tumble belt
To do the belt...
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Jun 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag washing machine
Hiya .. would suggest you having a look at the balance around the drum, ( normally heavy concrete blocks)... locate the fixing bolts and tighten them up ....should sort your prob.
Also make sure that the washer is fairly even and tight on its legs.. this is what usually causes the problem in the first place..
Regards Faggly
Mar 27, 2008 | Maytag Performa PAV3200
Hotpoint aquarius wma50
You should be able to do both without disturbing the motor.
To do the belt. + as long as your patience lasts...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
Mar 13, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
To do the belt...
Mar 07, 2008 | Hotpoint Aquarius WD63 Front Load...
How to replace belt on washer
Haha Yes With the very limited info you have provided us I still think I can help You just in the future be more specific. This is a Amana or Speed Queen washer?? To replace the belt Remove hoses from pump, remove wiring connector from motor, dislodge 2 front tub springs from tub end. Remove 4 -- 1/2 head bolts holding motor/pump frame to washer frame. Remove motor/pump from washer turn upside down. 3 Torx bolts hold pump to motor. Belt must be routed through pump proper. REinstall pump.
Dec 24, 2007 | Washing Machines
Zanussi FS1455W Front Load Washer Logo
73 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
